First post, by Tweaka
When I enable IPX in D-Fend (2.0.62) running DosBox 0.63 (tried 0.62 too) I get an error in the DosBox Console/status window that says "Unhandled IPX Function : 10".
When I use the command "IPXNET Starserver" that looks like it works...
"IPXSERVER: Connect from 127.0.0.1"
"IPX: Conneced to server. IPX adress 127:0:0:1:7:117
(still getting the error "Unhandled IPX Function : 10" thou"
when i try to open the network window in "C&C" and "C&C red alert" it results in errors and it hangs. Meanwhile, the status window is flooding out about a hundred of "read" and "write" errors per second.
the same happends to my other computer when I'm connecting to this sever. but it connects properly.
please help me with this problem
