First post, by andre_6
I was motivated by this comment at CPU Upgrade to try to install a 1.4GHz 512k Tualatin on a MSI 815EPT Pro board, even though it shows in the table as not supported:
"2019-06-29 00:41:50
Posted by: VENOM
I started the P III-S 1400MHz processor (SL6BY) on this mobo (BIOS ver. 7.4) at regular frequencies. Moreover, this processor accelerates under Win'98SE with regular FuzzyLogic4 utility up to 1600MHz."
https://www.cpu-upgrade.com/mb-MSI/815E ... 6337).html
I successfully updated the BIOS to version 7.4, posting and booting right after with my previous CPU into Windows 98SE. However as soon as I switched to the Tualatin it never booted. Am I missing something that this user might have done that I haven't? I left him a reply but as his post was a year ago I'm not holding my breath
Thank you for all your help and replies!
Reply 1 of 19, by Tetrium
I think you may have a better chance at contacting him via the forums there. I don't know if this user also frequents Vogons.
Personally I don't think I ever used the MSI 815EPT.
The CPU support list on the MSI webpage of this board also lists the 1.4GHz Tualeron (the Celeron variant of Tualatin PIII) as incompatible, perhaps due to MSI considering the board inadequately adapted for the increased powerdraw that the 1.4GHz parts would require? The 7.4 BIOS file was released after the 1.4GHz parts had already been released, so it's not like the parts didn't exist yet, thus not causing incompatibility that way.
If you can't find a way to get the 1.4GHz part working, perhaps you could opt to get the next best thing, which is the 1.26GHz Tualatin-s. Or perhaps you could try your luck and modify the BIOS (not recommended if you're new to all of this).
My retro rigs (old topic)
Report spammers here!
Reply 2 of 19, by andre_6
Tetrium wrote on 2020-09-28, 12:41:
I think you may have a better chance at contacting him via the forums there. I don't know if this user also frequents Vogons. […]
Thank you for your reply, I am not in any way qualified to venture in modifying the BIOS, although I thought of that as a solution that he might have applied. Didin't even remember the forums at that site, I will try to contact him there.
Thing is, at this moment now that I have this cpu I would prefer to go with it all the way through even with a new motherboard instead of spending pratically the same money on a downgrade. It really is a bummer that this is the only Tualatin model not supported by this board
Reply 3 of 19, by andre_6
In order to touch on all the possibilities to find a solution, is there a particular place in these forums where I could ask for someone to help me regarding modifying the BIOS?
Reply 4 of 19, by Doornkaat
There may be multiple revisions or versions of this board some of which do support the CPU while others don't. Try to find out wether your board is identical to the one the 1.4GHz CPU actually runs on.
If the board's power delivery is indeed a bit tight for the 1.4GHz model but somebody else got this setup working you may get lucky trying to replace the aged capacitors.
Reply 5 of 19, by PC Hoarder Patrol
According to MSI (and cpu-upgrade) you need a PCB v5 board for Tualatin support (even though MSI don't mention the 1.4-S PIII). Does this match your board markings?
The attachment MSI 815EPT Pro v5.jpg is no longer available
Reply 6 of 19, by andre_6
PC Hoarder Patrol wrote on 2020-09-28, 15:08:
Yes it does!
Reply 8 of 19, by andre_6
cyclone3d wrote on 2020-09-28, 16:00:
Do you know that the CPU you have is tested good? Did you test it in another board yourself to verify?
I bought it on Ebay, it was quality checked and previously tested by the Ebay store before shipping. I would test it myself if I could, but unfortunately Tualatin supporting boards do not come easy where I'm from, or at all. If that was the case, I wouldn't insist on this particular board.
The most frustrating is having the only Tualatin CPU that apparently the board does not support. That is what makes me think that it can't be that hard to start it, for people who know what they are doing, which this user I mentioned and quoted at my original post apparently does.
If he only updated the BIOS, or if there was a way to "read" the 7.4 BIOS complete changes list that this version provides, maybe I could find out if the only thing he did was to simply update the BIOS, thus turning my attention to my CPU being the problem.
Reply 9 of 19, by PC Hoarder Patrol
Weird, as it certainly seems to work on the board version I pictured. Here's a link to someone with the combo, who submitted a validated CPU-Z overclock entry
http://forum.pcekspert.com/showpost.php?s=686 … 0&postcount=212
The attachment 815EPT Pro LE5 on CPU-Z.jpg is no longer available
Reply 10 of 19, by andre_6
PC Hoarder Patrol wrote on 2020-09-28, 16:49:
Isn't MSI 815EPT PRO LE5 (MS-6337LE5) a different version from the MSI 815EPT Pro (MS-6337)? Seems like it
Is there any way to read the inner contents of this BIOS 7.4 version in order to see some kind of changes list? Do you think the user I quoted as a reference changed the BIOS so the cpu would run on it?
BTW as a reminder, I already installed this version and the cpu didn't post on it.
https://www.msi.com/Motherboard/support/815EPT_Pro.html
Reply 11 of 19, by Doornkaat
You could try underclocking it to 100MHz.
The board might also have a fail safe mode that'll clock the FSB @66MHz.
Reply 12 of 19, by PC Hoarder Patrol
AFAIK the only difference is the LE5 lacks the Promise FastTrak 100 chip / IDE connectors
Reply 13 of 19, by andre_6
PC Hoarder Patrol wrote on 2020-09-28, 17:09:
Thanks, it's a shame I can't test this on another board or apparently contact the guy that managed it to run.
Doornkaat wrote on 2020-09-28, 17:02:
I'm no expert at all, what would be the point of underclocking it? Just to see if it posts then change it back to 1.4Ghz and see if it keeps posting? Regarding that fail safe mode, what can I do?
Apart from all your suggestions as soon as I can I will retry to set it up again.
Because I updated the BIOS all settings changed to some default right? Do you think after the update he tinkered with some options before switching cpu's to the Tualatin?
Reply 14 of 19, by Doornkaat
The whole process is about narrowing down the problem:
Underclocking it either manually or by triggering fail safe mode will reduce power consumption and increase stability.
This way if it posts underclocked you know the CPU isn't completely dead and the board/BIOS has no problem with the CPUID. The problem is then either lackluster stability at high clocks or instable power delivery.
If there's an identical board running this CPU at full speed the board design is probably fine with the higher frequency so you could try recapping the board to stabilise power delivery.
The manual says there's a six pin jumper block in the upper right corner. It's layed out like this:
6 3
5 2
4 1
Short 5-6 and 2-3. This should have the CPU run at 66MHz FSB (700MHz core).
If it works you could also try 100MHz FSB by shorting only 5-6.
Also flashing the BIOS does not necessarily reset the CMOS. Try doing that yourself using the CMOS jumper.
By the way, reading the manual I just found out this board supposedly has an integrated POST diagnostic function using four onboard LEDs located left of the PCI slots. Compare their signal to the manual and tell us what they indicate please.
Reply 15 of 19, by cyclone3d
One other thing to note... just because a seller on eBay said that they tested something in a listing doesn't mean anything unless you saw them test it with your very own eyes.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 16 of 19, by andre_6
cyclone3d wrote on 2020-09-28, 20:38:
Doornkaat wrote on 2020-09-28, 20:09:
The whole process is about narrowing down the problem: Underclocking it either manually or by triggering fail safe mode will red […]
6 3
5 2
4 1
Thank you so much for your help and patience. So even if it posts after your process, the (eventual) solution would still require recapping? I don't have anyone available near me to do that.
I'm starting to think that I may very well need to acquire a new board and use the cpu on it, and use this MSI with my previous cpu. And if the problem persists with the Tualatin, present the problem to the store and go from there. Even without much choice nowadays regarding buying PIII-S Tualatins online, they were still very helpful
Reply 17 of 19, by pixel_workbench
I have a MSI 815ept pro V5, and that board had trouble starting up, until I figured out that it's caused by tight spacing around the ATX power connector. Some power supplies have a tab on the connector that's too wide, and on this board the tab can apply sideways pressure on the inductor right next to where the tab goes. That's what prevented the board from starting for me.
My Videos | Website
P2 400 unlocked / Asus P3B-F / Voodoo3 3k / MX300 + YMF718
Reply 18 of 19, by Doornkaat
Well, before we get too deep into all kinds of what ifs it may be best to just try those basic troubleshooting steps first. 😉
But regardless of what is going on with that particular board you should probably consider aquiring some basic soldering skills if you want to stick to this hobby. All of your hardware is going to fail sooner or later and from experience especially on hardware of this time period capacitors are usually the first thing to fail. Additionally worn/failing capacitors stress other usually long lasting components, so being able to replace them is very helpful at the very least.
Even though soldering seems rather scary at first it is actually pretty straightforward and replacing through hole capacitors is not a very difficult task. It just takes a little bit of practice and some decent tools (which can be had for less than 50$ total.) You can absolutely do this.😃👍
Reply 19 of 19, by andre_6
pixel_workbench wrote on 2020-09-29, 02:32:
Thanks for the suggestion, the board starts with my previous cpu with no problems at all, it's the Tualatin I wanted to apply that is the problem.
Doornkaat wrote on 2020-09-29, 03:03:
I understand, thanks for the encouragement. In this particular situation I would prefer to spend that money on another board (same amount funny enough) that I know is fully compatible than opening that particular can of worms at this point in time with no guarantees. You see, time for me is an issue right now. I have some time for now to complete this Tualatin build and install everything I want on it before it will be impossible for a long period to do anything on it. So you know, to buy the tools, learn, probably screw up, retry, get it right, but it may still not work... it's just faster and practical to use that money on another board, and keep this MSI board for another build in the future, or even trade it, who knows.
But you do raise a valid point, I will have to reserve time in the future to learn that. I'm just a casual user that wants to complete a build, but even so it makes complete sense to know how to keep them alive
