First post, by radiounix
So, I'm having some really weird trouble with my Unisys 486DX2/66 machine. It's a late PCI model with an intel chipset. I've had it for a few weeks, and I had it running Windows 95 stably and not really ever crashing. Then it started crashing, and eventually it got to where it would lock up after a few minutes just using DOS. After that, it started intermittently posting and locking up while loading DOS. Then not posting at all, and not showing output on a POST card. All within the span of a day, went from stable to not posting. I figured I just had a bad power supply.
I got and installed a old but unused ATX 1.0 Seasonic power supply with an adapter, and all was well for a few hours. I ran two cycles of Memtest 86 with no issues and checked the basic hardware with Amidiag. It was fine until I tried to copy over the C drive partition with Ghost and a laplink cable, locked up twice in a row. I tried to Laplink over the Ghost image file in DOS, but that crashed three times in a row after about twenty minutes or so. After the third Laplink try, it wouldn't post when I turned it off and back on again. It's now erratic, sometimes posting and sometimes not, seems to be getting worse, first stopped booting off a floppy, now crashes early in the POST. I was finding pulling the CMOS battery and waiting a few minutes would get it to post again if it wouldn't otherwise. The post card shows the machine stopping at various points in the boot, but often around the point where it accesses the floppy controller. I've seen it occasionally state that the CMOS battery is dead -- it's new and measures at 3.1 volts on my multimeter.
I have the machine down to just the one, original 500MB hard disk. I've removed the cache, the second RAM module, and all expansion cards. I've tried turning everything off in the BIOS, including shadowing, the floppy controller, the cache, APM, .etc. Makes no difference.
Any ideas? Is this really just two bad power supplies in a row?
Reply 1 of 2, by radiounix
Huh. So it's been mostly working today. It made it through four passes of memtest86, I ran it through a Spinrite cycle on the hard disk, and I did Ghost Windows back onto the drive without issue. QA FE didn't find any issues. It was throwing a blue screen fatal exception error booting into Windows 95, not always at the same time. I put a 1 watt dropping resistor load on the 3.3 volt rail and the blue screen only happened once since, as soon as I tried to use the CD-ROM drive. Just a hunch. I looked over at Scott Mueller's classic Upgrading and Repairing PCs, and I suspect I have been having intermittent Power Good issues.
I now suspect it really is just two bad power supplies in a row. I've tested the voltages and I get 11.92 and 5.02 while operating the computer. The 3.3 was over 3.4 without the dropping resistor, and is 3.15 with the dropping resistor. I don't have an oscilloscope to test it for ripple, and I don't really want to buy a third power supply for my one desktop.
Forgot to mention, I'm getting buzzing and chirping sounds from the PC speaker under disk access and some other system activities. Repeatable, same times. I hadn't had this before the instability saga.
Anyone have any ideas? I'm going to go ahead and recap the Seasonic, but is there anything else I can try?
Reply 2 of 2, by radiounix
Oops. So, I did just figure out the source of the PC speaker noise. Looks like I had my PC speaker/case LED header backwards!
