First post, by Intel486dx33
I have a few builds with the AMD 5x86-P75-133-ADW CPU.
I have been able to over lock them to 160mhz fine.
I was wonder what kind of overclocking success have uses had with the AMD 5x86-p75-133-ADZ Variant ?
Wikipedia posts that they are suppose to be better suitable for over clocking ?
Maybe they can endure higher temps longer than the ADW variant. But performance wise they perform the same.
Reply 1 of 7, by kixs
There are rare chips that will do more then "standard" 160Mhz. I have one stable at 180 and it also POSTs at 200.
Reply 2 of 7, by The Serpent Rider
They aren't that different in terms of overclocking. Both will require sufficient cooling to work stable at 180-200 Mhz.
Reply 3 of 7, by Intel486dx33
Yes, from what I have read I don’t see much of a performance boost @180mhz. Over 160mhz. And at 160mhz it is much more stable.
Reply 4 of 7, by uridium
I'm running one @150mhz stabilly for several years with a P4 heatsink thermal epoxy 'd on it. Solid as a rock. Going >150mhz is diminishing returns given ram speed on my board @3x50mhz.
Reply 5 of 7, by kixs
What are your wait states for the memory and cache? With 4x40 you can have them at lowest possible.
Reply 6 of 7, by Intel486dx33
kixs wrote on 2020-09-30, 11:44:
Yeah, watch this video and see what bios settings works best with your motherboard.
https://youtu.be/jlQXS1VrFUQ Bios settings:
Here is my build:
AMD 5x86@160mhz., Media Vision PAS16. ( Win 95 )
Reply 7 of 7, by kixs
I asked uridium what are his timings @50MHz FSB. I know my way around BIOS and stuff 🤣
