First post, by appiah4
I'm in the process of replacing an SS7 AMD K6-2 with a S370 VIA C3 and I was wondering what kind of cooling solution it requires. Is it a lightweight CPU like the Celerons, or do I need something capable of cooling the faster Coppermines/Tualatins?
The CPU in question is a Samuel C3 667 (133x5.0, 2.0V)
Reply 1 of 3, by The Serpent Rider
Celeron cooler will suffice.
Reply 2 of 3, by appiah4
The Serpent Rider wrote on 2020-09-30, 17:26:
Would an AMD K6-2 cooler also work, or would that not cut it?
Reply 3 of 3, by The Serpent Rider
Celeron Mendocino and typical late Socket 7 coolers are more or less identical.
