Resound 2 alternatives?
First post, by Nitroraptor53
I love the Resound 2 but I want Digital sound sampling. Problem being; I can't afford this: https://www.ebay.com/itm/Sound-Blaster-Pro-2- … ng/174409282114?
Are there any clone cards that have Digital Sampling? Thanks in advance!
Reply 2 of 8, by maxtherabbit
Tiido wrote on 2020-10-01, 00:50:
LABS' BlasterBoard would be a good choice I imagine.
For MCA?
Reply 3 of 8, by Nitroraptor53
It isn't for MCA... but I'll ask him if there's any possible way to adapt it to an MCA bus.
Reply 4 of 8, by cyclone3d
You can always use a logic analyzer to capture the digital output directly from the OPL3 chip.
OPL3 Digital Decoder
OPL2 vs. OPL3 Audible differences, digital recording comparison
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 5 of 8, by Tiido
maxtherabbit wrote on 2020-10-01, 00:54:
For MCA?
Whoops 🤣
For MCA I am not aware of anything, except maybe TubeTimeUS might be conjuring up something since a lot of work had been put into getting MCA bus conquered by that guy...
Reply 6 of 8, by matze79
Why not just hook up a DAC to LPT, you can play Wave in Windows and use a couple of Mod Players, Trackers, even MP3 Player, Wav Players, and a Handful of Games.
With some variants even Stereo is possible.
But i would recommend a Active Device with own Bus Driver and own Power Source.
Otherwise you will always get bits of noise from the Computer.
Reply 7 of 8, by Nitroraptor53
matze79 wrote on 2020-10-01, 18:14:
I'm not sure what you mean by hooking up a Digital-to-analogue converter to the printer port. It there a specific one for the parallel port? I'm no expert to vintage computing so idk.
Reply 8 of 8, by Oetker
Nitroraptor53 wrote on 2020-10-02, 01:14:
Yes a Covox clone, there's info enough on Vogons. There's also parallel port OPL boards, might be easier to get than a Resound MCA.
