First post, by pentiumspeed
Say I have a wide 68pin controller card connected to the LVD or ultra160 or ultra320 drives? I know about the proper adapters in between on each drive.
Just wanted to know for sure this was from one of the thread's post that talked about cross compatibility between controller card and drives.
Cheers,
Great Northern aka Canada.
Reply 1 of 5, by darry
pentiumspeed wrote on 2020-10-01, 20:40:
Cheers,
LVD and SE devices (cards and disks) of various speed ratings will talk to each other . Use passive adapters if necessary and terminate appropriately . The max speed on a given SCSI chain will be the highest speed supported by all devices .
HVD disks and controllers will only play nice among themselves,unless using special activeadapters/converters to allow communication with LVD or SE . Without such adapters/converters, something will fry if HVD and LVD/SE are connected together .
Reply 2 of 5, by Disruptor
Use an Adaptec 2940U2W
It has an integrated bridge chip AIC-3860Q
That means when you use SE and LVD devices on the same controller, the LVD devices aren't slowed down to SE compatiblity mode.
Extending a SCSI bus with Adaptec AIC-3860Q (2940U2W and more)
Reply 3 of 5, by darry
Disruptor wrote on 2020-10-01, 23:04:
Use an Adaptec 2940U2W It has an integrated bridge chip AIC-3860Q That means when you use SE and LVD devices on the same control […]
Thank you. Good to know.
Reply 4 of 5, by pentiumspeed
Adaptec 2940U2W can I use it as non-raid mode, like two hard drive, one of them for boot?
Cheers,
Reply 5 of 5, by Disruptor
The Adaptec 2940 controllers do not support RAID.
