First post, by Mephusto
I am currently starting the process of building my windows 98 PC. I am mostly trying to stay period correct but somethings I may upgrade just for a better experience.
Mobo - Intel SE440Bx
CPU - Pentium II or Pentium III both are 450mhz
320mb ram (yes I know a little overkill)
GPU - either nvidia riva tnt2, geforce2 mx400, or ati rage 128
Also I have a Voodoo2 12mb
Sound - SB Live! CT4620, CT4660, & CT4860 LiveDrive.
Pci usb 2 card
128gb sd to ide
DVD-rw or CD-rw
3.5 floppy
Zip drive
Hopefully a network card if I can find one
2 cases to decide from
    970.19 KiB
    895.22 KiB
    888.08 KiB
    913.92 KiB
    605.97 KiB
Reply 1 of 8, by Mephusto
Some more pictures. I'll post some more when I get home and can get more pictures.
Oh and I am going with 98 SE
(Edit to add details)
    409.07 KiB
    800.52 KiB
    492.42 KiB
    449.28 KiB
    358.06 KiB
Reply 2 of 8, by chinny22
More or less my PC I got in Jan 1998, your even following a similar upgrade path
Got a 24/4/4 burner in 99. GF2 MX in 2001 or 2002, DVD-Rom late 2002 early 2003.
Never had a Voodoo 2 back then but this is the perfect PC for one!
Reply 4 of 8, by Mephusto
Doornkaat wrote on 2020-10-04, 15:13:
That's going to be a nice PC, plus you can still do a lot of upgrades should you find it too slow. 👍
Also personally I'd go with the GF2 MX400 if you have the V2 to go along with it.
Thanks I appreciate it! 😀 I also have an fx5500 256mb that I could throw into it too. my dvdrw unfortunately doesnt work so I am going with the dvd r and maybe even with the cdrw both in it. I am still hoping that I can get a better case too. I am all for thoughts and opinions and ideas for it 🤣.
Reply 5 of 8, by pixel_workbench
I'd reconsider the USB2 card. I had one in my P2 400 retro rig, and noticed that it ate up about 10-20 percent performance. If transferring files often, might want to get a network card instead, and set up a shared folder. If not, then wait for the occasional transfer to complete with onboard USB1.1, it's not like old games took up a dozen gigabytes of space.
My Videos | Website
P2 400 unlocked / Asus P3B-F / Voodoo3 3k / MX300 + YMF718
Reply 6 of 8, by Mephusto
pixel_workbench wrote on 2020-10-09, 19:42:
Oh thank you so much. I did not think about that much usage for that card. Do you think the PIII would be better than the PII? I still havent had a full day off work to put it together and it is killing me 🤣. Also I have 1 network card and it has 98 drivers but I don't remember how to get the networking set up on the old OS's
Reply 7 of 8, by jasa1063
Mephusto wrote on 2020-10-09, 21:23:
I can verify the performance loss with a USB 2.0 card. I had the same results in the my Intel SE440BX-2 system. Took out the USB 2.0 card and the performance of my Intel Pro/1000 GT network card went up by that 10-20% amount.
