First post, by Baoran
How do I know if the cardbus slots on an old laptop are 3.3V or 5V slots? The specs shown online generally just tell if the slot is type II or type III but don't tell the voltage.
Reply 1 of 10, by Thermalwrong
The slots and cards are keyed, so a 3.3v Cardbus card should not be able to fit into a 5v only PCMCIA slot. Usually Cardbus is only present on Pentium MMX laptops and later, but like you say it's often not shown on the laptop itself.
Cardbus was a pretty massive jump in spec (ISA > PCI) so it's usually stated quite clearly in the specifications of any laptop that has it.
Reply 2 of 10, by Baoran
Thermalwrong wrote on 2020-10-10, 12:59:
I figured that out about not fitting, but I would like to know before getting the card if it will work with a laptop or not instead of buying a card and only then realizing that I can't put it in the slot.
Reply 3 of 10, by dionb
Baoran wrote on 2020-10-10, 13:55:
Firstly get terminology straight:
PC-Card: anything about that size you can stick into a (mobile) PC
PCMCIA: basically 16b ISA bus, 5V
Cardbus: basically 32b PCI bus, 3.3V
How to recognize if seller doesn't sound like he knows the difference:
The attachment 16bit_vs_CardBus.jpg is no longer available
That copper grounding strip is a dead giveaway for Cardbus.
Reply 4 of 10, by mkarcher
If the description is accurate (which admittedly is bold assumption on used computer sales, and still risky on original documentation), "PCMCIA" means a 5V only slot that is ISA-like, "CardBus" means a 3.3V slot that is PCI-like. All CardBus slots I know can fall back to 5V ISA mode. For cards, CardBus card have tend to have a gold-colored shield at the connector, whereas PCMCIA cards have an unshielded plastic connector.
If you already have the laptop at hand, you can also check what driver is in use for your PCMCIA or CardBus controller. Or you can use a flashlight to check the connector keying in the slot.
Reply 5 of 10, by Baoran
The seller basically says it is a 3.3V cardbus card and also says in description that because it is 3.3V it won't work in all pentium 2 or earlier laptops. Mainly I am trying to figure out if it works in some of those or if all Pentium 3 laptops have the 3.3V slots and if there is a way to figure it out by looking at the slot in the laptop. I know the differences in cards themselves, but I am trying figure out the differences in laptops themselves.
Reply 6 of 10, by dionb
Baoran wrote on 2020-10-10, 15:51:
That's probably something to look up in the specs of the laptop. It depends on the bridge chip used.
Reply 7 of 10, by mkarcher
Have a look at this image on wikimedia commons comparing the keying of a 3.3V cardbus and a 5V PCMCIA card. You will notice the wider key on the 3.3V card. If you manage to get good lighting and vision into the PC Card slot, you can check the receptacle for the size of the notch where that key needs to fit in.
Reply 8 of 10, by Gamecollector
mkarcher wrote on 2020-10-10, 14:57:
No, the 5V only 16-bit PC Cards support it's optional.
Looks like the only way to detect is "plug and pray". 😀
Reply 9 of 10, by Baoran
Gamecollector wrote on 2020-10-10, 23:55:
If what Dionb said earlier is true it would mean that if the laptop specs say word "cardbus" it would mean automatically that it is 3.3V slot, right? That is if I understood correctly that there isn't 5V cardbus cards and it would just say PCMCIA without cardbus if it was a 5V slot.
Reply 10 of 10, by ragefury32
Baoran wrote on 2020-10-11, 01:35:
Cardbus IS PCMCIA. It’s just a later PCMCIA standard that ran on 3.3v, is 32 bits and speaks PCI underneath. Cardbus slots can run on both 3.3v and 5v for backwards compatibility.
