First post, by adalbert
Looks like I have two of my ZIDA 4DPS boards bricked now, all 3 BIOS chips I have (one spare) seem to have gone bad which seems weird, so I would like to get some opinions on that - is it really just a BIOS problem and bad coincidence, or should I look for another cause.
V2.1 board with TVGA8900: BIOS ROM checksum error "INSERT SYSTEM DISK AND PRESS ENTER" message, low beep, very low beep
Same board after a reboot: different message (Drive A error. System halt) and high looping beeps
V2.11 board with original UV-EPROM and TVGA8900: no image, 0D POST code, one long beep, two short beeps
V2.11 board with another UV-EPROM (spare one) that was still good 4 years ago: low beep, very low beep, garbled screen
V2.11 board with no VGA: 0D POST code (one long beep, two short beeps), then 41 POST code, looping high beeps
I also tested both boards with PCI S3 Trio: no image, one long beep, two short beeps
Could it be just a problem with the BIOS / UV-EPROM chips? Could all three of them have simply erased themselves after several years? (UV window was still covered with the sticker). If so, I guess I should buy TL866...
AT(X)Anything: a modular DC-DC PSU for old PCs (open hardware)
