First post, by foil_fresh
See the image attached - do the numbers printed on the cpacitor indicate certain values? Or is this just for the manufacturer?
This is a cap ive accidentally bent over while taking off the heatsink last night. It is one of two identical caps that sit between the ram chips. I dont really want to power this up without knowing it's in good condition so it needs to be replaced.
Thanks.
    234.21 KiB
    Capacitor top
    550.23 KiB
    Side view of damage :(
