MS5129 PS/2 header
First post, by fool
This motherboard has 2x5pin PS/2 header. Pin pairs seems to be shorted so that it is actually a 5 pin connector. I found out Vcc and GND pins with multimeter and thought DATA and CLK pins are two that has high impedance towards GND.
Connected mouse as follows from top (keyboard conn.) to bottom:
1. CLK or DATA
2. DATA or CLK
3. GND
4. NC
5. Vcc
Connecting this way just makes keyboard go crazy and does not work. Swapping DATA and CLK does not help so there seems to be something or more wrong.
Someone know pinout for this? Probably MSI has other mobos with the same header.
Toshiba T8500 desktop
SAM/CS9233 Wavetable Synthesizer daughterboard
Coming: 40-pin 8MB SIMM kit, CS4232 ISA wavetable sound card
Reply 1 of 3, by zyga64
I have Shuttle Hot-553 with somewhat strange mouse connector. Maybe your is similiar to this ? I tried only variant B and it works
Scamp: 286@20 /4M /CL-GD5422 /CMI8330
Aries: 486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
Triton: K6-2@400 /64M /MGA-2064W+3dfx /ES1370
Seattle: P!!!750 /256M /MX440 /Vibra16s+SBLive!
Panther Point: 3470s /8G /GTX750Ti /HDA
Reply 2 of 3, by fool
Finally got it right.
It's combined mouse and keyboard header. Mouse on on the left side and keyboard on right. That's why keyboard turned crazy when I connected mouse and keyboard parallel.
I dont't know which ones are CLK and DATA, but basically it's like this if someone needs this later. Notice PIN 1 is facing towards keyboard DIN connector in the picture!
The attachment MS5129_conn.JPG is no longer available
Reply 3 of 3, by Horun
Good work !
