First post, by pingvinen
Hi all.
I have a client that are running Windows 10/32 due to the fact that they have a legacy DOS (VB4DOS) application that they can't port to modern architecture. No source code and the author is long gone. The app prints invoices and BOM for shipping directly to LPT1. So I have redirected LPT1 to a shared network printer, and that works great.
NET USE LPT1 \\127.0.0.1\shared-printerNote: The physical LPT1 port is disabled in BIOS for this to work.
So, I would like to investigate if DOSBOX would help us to run the VB4DOS app in a Windows 64 bits host instead. I have played around with both DOSBOX and DOSBOX-MB6, and the app runs fine (when I mount the needed drives, C for local HD and F for a network drive where the database resides). However, I am completely lost when it comes to Printing.
A second issue might be that the database used by the app is on a network drive mapped to F:, shared by multiple users. So if DOSBOX is the solution, there must be support for networked drives (or other tricks).
I will continue to scan the forum, but if anyone have any guides or instructions for me, I would be so very grateful.
