First post, by DeckardGames
DeckardGames
Offline
- Newbie
Greetings
I've searched around some info on mobos for the voodoo 5 cards, especially when it comes to the 3.3v agp slot.
An AGP 1.0 or universal AGP slot should to the trick I believe.
My question is, I have an MSI 815e pro which, supposedly, has an AGP 4x/2x universal slot. The problem is that the bios doesn't have any info on the actual voltage on the AGP slot.
Will it be safe to use it with the voodoo 5?
https://www.msi.com/Motherboard/support/815E_Pro
Thanks for the help.
