First post, by Robhalfordfan
hello all
after updating the bios in my 486 build the system hangs on updating escd and the keyboard stops working or freezes
i have discovered - it doesn't hang if disable the external l2 cache in bios or take out the chips
the l2 cache worked fine before the bios update which is on an eprom (hoping replacing it with a flash rom to it original bios at some point as my mobo has a jumper for eprom or flash rom)
the mobo is atrend atc 1415
if i am needing to replace l2 cache chips and if so where is good place to find and buy them
the manual say my mobo support any
32kx8 - 128kb
64kx8 - 256kb
128kx8 - 512kb
the tag ram uses
8kx8 - 128k
16kx8 or 32kx8 - 256kb
32kx8 - 512kb
pic of current l2 cache chip below
    399.04 KiB
    current l2 cache chips
Reply 1 of 27, by SScorpio
When you flash a BIOS, settings can be restored to defaults. The -15 in the name can mean 15ns, go through the BIOS and see if there is anywhere to set that. It also looks like you have 256KB of cache as you have 4x512Kb and the 256Kb may be a parity chip.
Reply 2 of 27, by Robhalfordfan
SScorpio wrote on 2020-10-23, 19:10:
had a look and defaulted the bios and can not see anything about ns timings
here pics of what settings the bios has
    1.21 MiB
    bios screen 1
    973.15 KiB
    bios screen 2
Reply 3 of 27, by cyclone3d
What BIOS version did you come from and go to?
Are you sure the BIOS you upgraded to is not for a different revision of the motherboard?
Are the cache jumpers set properly?
Yamaha YMF7x4 Guide
Epstein didn't kill himself
Reply 4 of 27, by Robhalfordfan
cyclone3d wrote on 2020-10-23, 19:36:
the cache jumper set when i got the mobo original and worked before and haven't changed anything there
i can't remember what version the original bios was but pic below with label on it
file.php?mode=view&id=94757
the version i updated was
file.php?mode=view&id=94758
i didn't find any other revision of my mobo and went to a website i use before when updating my socket 7 penitum build a while and seem to be ok
i have attached pic and the rom file of both bios
original bios - i backed up via awdflash before i buggered the eprom
the updated bios - i used to flash to new eprom via a programmer
    1415v33-bios.zip
    74.48 KiB
    7 downloads
    updated bios
    ORI_BIOS.zip
    82.24 KiB
    7 downloads
    original bios rom backup
    488.16 KiB
    updated bios
    580.38 KiB
    orignial bios chip label
Reply 5 of 27, by Robhalfordfan
been looking for my original bios just in case if my backup is screw in some way and found this and it seen to be closer or was my original bios
http://chukaev.ru54.com/bios_en.htm#z3zzm002: … 532c394f0ca82f0
looking at the ic chips in this link and my l2 cache chips matches, along with chipset, along with via chip (VT8235N) and the odin chip (OEC12C885)
Reply 6 of 27, by Horun
Couple things: Your cache cannot go bad just because you flashed the BIOS. It looks correct for 256K using 4 chip+TAG.
TRY: Set the L2 Cache Update Scheme to WR-Through like L1 is and see what happens. ( I can see that is the other choice in the new BIOS)
Ok I cannot extract the "original.tmp" from your original bios backup but can from the new one so am guessing it was not backed up properly or got corrupted while saving,
even my Award util can only see the NCR portion properly but can see all of the newer BIOS sections properly.
Reply 7 of 27, by jakethompson1
Can you remember whether the original BIOS had that "Plug and Play BIOS Extension"?
PnP BIOS and ESCD are intertwined, and I believe ESCD requires a flash BIOS. So that may be related since we thought your board isn't capable of flashing a BIOS.
Reply 8 of 27, by Robhalfordfan
jakethompson1 wrote on 2020-10-24, 01:44:
I think it did have plug and play bios extension, same version aswell
And I thought my board wasn't capable since it was an EPROM but I noticed the jumper on the mobo and looking in manual that it can be change to a flash rom and though I can't any more harm to mobo, so why not try
i have been using the machine with l2 cache off and testing it out with dx4 100 and noticed the machine is a little unstable, as the system would kinda not response but not lock up as i could still move the mouse and use the keyboard after using for a little while and had one instant where the machine rebooted itself but only once
Reply 9 of 27, by Robhalfordfan
Horun wrote on 2020-10-24, 00:42:
Couple things: Your cache cannot go bad just because you flashed the BIOS. It looks correct for 256K using 4 chip+TAG. TRY: Set […]
I did try changing l2 update scheme to write through and nothing changed, same as before
I thought the original backup was maybe it did get corrupted while backing up
But in reply below that is a link to what I think is my original bios (not my backup)
Reply 10 of 27, by amadeus777999
Return to the old BIOS and try the configuration, no cache + DX4, to see if the instability issue persists.
Also the new / different BIOS may not be fully compatible - I had a similar issue with a P60 board where a "compatible" BIOS version would screw up everything.
Getting new cache chips is hairy as most, even the slow ones, are fakes. On ebay sellers from France sometimes carry original chips.
Reply 11 of 27, by Robhalfordfan
amadeus777999 wrote on 2020-10-25, 11:11:
that is what i am thinking and waiting to try a flash rom instead of eprom and hopefully it will "fix" my issues, fingers crossed
i am aware on fake chips on line and original ones are harder or more expenisve to find/buy as i imagine they are not "made" anymore
Reply 12 of 27, by Robhalfordfan
my flash rom arrived and flash the bios from the weblink above which is v3.20 and with l2 cache on it gets past updating escd... and starting booting from hdd or a floppy disk and say starting ms-dos and then nothing but again turning off l2 cache altogether works fine
changing the l2 cache to write through or write back makes no different
just rule out the cpu (which intel 486 dx4 100), i use a intel dx2 66 which works before no issues and does the same as the dx4
both cpu's are write back
prob a stupid question/idea but is there a way to compare the original bios backup with one of the later ones to see what different or got corrupted in original backup
dont know if this would help but the checksum of original bios backup is 061FH - i think - according to award flash program
if anyone has same board and bios eariler then v3.20, able to make a backup and sent to me
Reply 13 of 27, by amadeus777999
Maybe a simple way to compare Bios's is to generate a hash via the crc/sha functionality that comes with 7zip - right click after install and you can generate "hash" keys from files.
Maybe one of your srams is defect... you may need a second set for testing.
Reply 14 of 27, by Robhalfordfan
amadeus777999 wrote on 2020-10-27, 21:29:
i have no idea how to do that and could try since this all new to me and i am learning and nothing wrong with learning something new during current state of the world
maybe one the sram chip is defected - doesn't explain how before the "bios update" that it all worked fine but that was the breaking point
would any sram chips work as long as it cache size and timing are the same
Reply 15 of 27, by debs3759
Any sram chip with the same specs would work.
Reply 16 of 27, by Horun
Robhalfordfan wrote on 2020-10-26, 18:13:
my flash rom arrived and flash the bios from the weblink above which is v3.20 and with l2 cache on it gets past updating escd... […]
All the 486DX2-66 were write-through except the SX955 SL version was write-back cache. Similar to DX4-100, all were write-through except the SK096 chips. What are the S spec of the cpu's you are trying to use ?
Reply 17 of 27, by jakethompson1
Robhalfordfan wrote on 2020-10-24, 11:25:
How did you dump the backup? The good news for troubleshooting is I'm pretty sure it is just a corrupted version of the V3.20 bios you posted. The compressed original.tmp is stored in the first 0xff49 bytes; only a few bytes in that section differ:
$ cmp -l 4umw002.bin ORI_BIOS.ROM | awk '{ printf "%5x %2x %2x\n", $1, strtonum("0" $2), strtonum("0" $3) }'
1 25 0
2aab b1 11
5556 3f 0
If I "repair" those bytes using a hex editor in fact it's possible to extract original.tmp from your ORI_BIOS.ROM, and it indeed has the 3.20 version inside.
This doesn't solve the mystery of why you are having trouble with cache though. You definitely cleared your CMOS with the jumper if you had one, and did "Load Power on defaults" and "Load BIOS Defaults" in setup before you started messing around? As Feipoa has in his MB-8433UUD manual there may be hidden CMOS settings you can't see that change between bios versions, and that you can only reset using the "Load defaults" settings.
There's no way you inadvertently bumped off a cache-related jumper when you were messing with the bios chip?
Reply 19 of 27, by Robhalfordfan
Horun wrote on 2020-10-28, 02:25:
my dx2-66 is sx955
my dx4-100 is sk101
