First post, by tomexplodes
Just as an example, I made a doom.bat file so I could install and uninstall novert.com before and after running doom.exe, but simply typing doom runs the executable, not the batch file. This is no big deal, I renamed doom.exe to doom1.exe and did it that way, so it's not something that's necessary, but I was just curious. Thank you!
1.) MS-DOS 6.22, Pentium-S 90mhz, 32mb RAM, S3 Trio64, Vibra 16
2.) Windows 98 SE, AMD Athlon XP 3000+ 2.1ghz, 512mb RAM, Geforce 4 TI 4200 128mb, Sound Blaster Live! Value
Reply 1 of 9, by Jo22
It's a matter of the command line interpreter (CLI) .
By default, DOS uses command.com, which uses this order:
.com
.exe
.bat
On Windows, there's PATHEXT= variable, also.
https://stackoverflow.com/questions/605101/or … -a-bat-vs-a-cmd
You may want to try an alternate CLI, such as 4DOS.
Maybe it can be configured in a way that suits your needs. 😀
Edit: Alternatively, there are also batch file converters.
They "compile" batch files and create COM or EXE files.
They can be find in shareware archives (simtel, night owl etc) online or on old CDs.
Reply 2 of 9, by tomexplodes
Okay, good to know. Like I say, not difficult to work around, just wanted to know. Thanks for the info! I'll take a look at 4DOS.
Reply 3 of 9, by Errius
I've always put program launching batch files in C:\DOS.
Is this too much voodoo?
Reply 6 of 9, by jakethompson1
Do you use doskey? Could set up a macro.
Reply 7 of 9, by Errius
Jo22 wrote on 2020-10-24, 18:08:
It's a matter of the command line interpreter (CLI) . By default, DOS uses command.com, which uses this order: .com .exe .bat […]
.com
.exe
.bat
What does DOSBox do if there's also an internal DOSBox command with the same name as an external file?
I seem to remember problems from having LOADFIX.COM on my system. It had different syntax to the DOSBox command and was launched first. This caused much confusion until I realized what was happening.
Reply 8 of 9, by jmarsh
Internal DOSBox "commands" are actually executables on Z: drive, so they get chosen based on $path like regular programs.
Reply 9 of 9, by Errius
Aha, that explains it. I have Z:\ at the very end of the path.
