First post, by ReignerDeustcher
Tried 'mixer cdaudio 20:20' and 'mixer cdaudio -d15' and does nothing
also in the mixer list of dosbox doesn't appear cdaudio, just appear sb, master,spkr, fm
ah you have to mount the cdrom or cd image first. Else the mixer command doesn't work
Water flows down the stream
Qbix wrote on 2020-10-28, 07:40:ah you have to mount the cdrom or cd image first. Else the mixer command doesn't work
thanks!
