First post, by ReignerDeustcher
Sombody knows if is there some command for executing the game with better graphics like the one in nascar 1? (c:\nascar\nascar -h)
If i use ''nascar2 -h'' doesn't work
Reply 1 of 14, by Cobra42898
it appears to be in the menus in-game.
Searching for Epson Actiontower 3000 486 PC.
Reply 2 of 14, by ReignerDeustcher
Cobra42898 wrote on 2020-10-28, 21:49:
yes, i have the graphic option in 640x480 but the problem is that the game looks worse than nascar 1 using -h command, 🤣
Reply 3 of 14, by kjliew
The game supports 3Dfx Glide. This is your best option for the highest graphics details at 30FPS at any views and any number of opponent cars drawn. Use a glide wrapper and you can upscale from 640x480 at any resolution you wish. I could do the drive practice of the 1st circuit at locked 30FPS at 1280x960.
Reply 4 of 14, by ReignerDeustcher
kjliew wrote on 2020-10-28, 23:09:
but how do you set that custom resolutions? i've searched about 3dfx in dosbox but i don't understand
Reply 5 of 14, by _Rob
3dfx emulation and glide wrapper/pass-through are not the same thing.
- 3dfx emulation typically refers to low-level emulation of the 3dfx voodoo adapter. A disadvantage of this mode is that it is slow and limited to the original cards limits
- glide wrapper (or pass-through) instead replaces the games glide2x.ovl file with a special patched version that passes through the Glide API calls to the host OS, where you then need to have a Glide wrapper installed to convert those Glide calls to OpenGL/Direct3D/Vulkan. This is much faster and allows extra features not possible otherwise. But it is limited to games using the stand-alone glide2x.ovl file.
Reply 6 of 14, by kjliew
_Rob wrote on 2020-10-29, 13:05:
... But it is limited to games using the stand-alone glide2x.ovl file.
That wasn't quite a limit at all. DOS glide games with static linked OVL are minority. Windows Glide games are all dynamic linked DLL.
It should also be noted that Voodoo1 emulation is far from perfect, a fact that most had chosen to ignore and perceived low-level emulation could have been more accurate despite its performance penalty. High-level Glide pass-through supports much more 3Dfx games than voodoo1 emulation when paired with modern Glide wrappers such as dgVoodoo2 or nGlide.
ReignerDeustcher wrote on 2020-10-29, 06:16:
Custom resolutions are specific to Glide wrappers. You need to look for the documentation of your chosen Glide wrappers. Google is your friend.
Reply 7 of 14, by ReignerDeustcher
kjliew wrote on 2020-10-29, 20:07:
That wasn't quite a limit at all. DOS glide games with static linked OVL are minority. Windows Glide games are all dynamic linke […]
tried nglide, did what the website says and the game looks the same, tried dgvodoo also, copied all the dll's to the folder of dosbox and there's some white window that appears when i launch the dosbox and then it crashes
Reply 8 of 14, by kjliew
You did patch up the game for 3Dfx Glide, didn't you? It should give you NAS3DFX.EXE to run the game in Glide hardware accelerated 3D. You also need to use or compile a version of DOSBox with Glide pass-through patch. It is not available on official build.
Reply 9 of 14, by ReignerDeustcher
kjliew wrote on 2020-10-30, 15:08:
and how i patch the game? i downloaded a N2-3DFX.exe patch that doesn't run in dosbox (ask for windows) and not in win 10 either
Reply 10 of 14, by kjliew
Copy n2-3dfx/*.* and patch/*.* to your game folder.
Run PATCH.EXE to update the game. This is N2PAT0 and will upgrade 1.0o to 1.03.
Run NAS3DFX.BAT to activate Glide renderer.
    n2patch.zip
    2 MiB
    90 downloads
    n2patch
Reply 11 of 14, by ReignerDeustcher
kjliew wrote on 2020-10-31, 06:54:
thanks! but doesn't work, the .bat shows the 3dfx logo and then crashes
Reply 12 of 14, by kjliew
It works for me both on DOSBox SVN and QEMU using OpenGlide.
Check DOSBox console output if Glide pass-through or Voodoo1 emulation was in effect. It is mostly due to your DOSBox setup issue. The game plays great on DOSBox and QEMU at high resolution upscaled, up to 1600x1200 on my 2560x1440 panel. Though, I wasn't quite a fan of NASCAR.
Here's an example at 1280x960
574.6 KiB
NASCAR2 3Dfx
Reply 13 of 14, by ReignerDeustcher
kjliew wrote on 2020-10-31, 20:53:
It works for me both on DOSBox SVN and QEMU using OpenGlide. […]
now tried the dosbox svn and openglide and says unable to load dll 🤣, what an annoying thing
Reply 14 of 14, by Neville
ReignerDeustcher wrote on 2020-10-31, 23:12:
Increase DOSBox's memory to 63 Mb, that solves many 3Dfx games that show that error.
