First post, by cprieto
Any hints about this video card and support in Windows 3x or NT 3.x? I got one of those HP thin computers with a Crussoe CPU and I was thinking in trying it with old Windows (pre 95) on it (and of course some DOS stuff).
Reply 2 of 10, by cprieto
Thanks @matze79 but sadly it didn't work 🙁 I will try with one of the old Trident cards I have at home because the max I could do with the integrated Radeon R100 has been VGA and lower resolution.
again, thanks
Reply 4 of 10, by cprieto
Thanks again @matze79 but I think I gave up. I tried with SciTech drivers, 5x, 6x and 7... No luck neither. The MSDOS driver says no compatible SVGA display chip is found, when I try and run manually VBETEST in version 6.x I can see it can correctly display the color and patterns at 1024x768 and 16bit colors so it can clearly handle the DAC but I have no idea how to go and tell it "hey, I know you don't detect a compatible chip and all that stuff but believe me, it works" and then from there tell Windows to do the same...
This hobby is getting harder than I expected 😁
Reply 5 of 10, by zyga64
Try this one: https://sites.google.com/site/chitchatvmback/misc
https://bearwindows.zcm.com.au/win31x.htm#2
https://www.japheth.de/Download/Win16/svgaptch.zip
8088@8 /640k /TVGA9000C /ALS100+TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 6 of 10, by cprieto
Nah @zyga64 I tried already patching the svga256 driver with vgapatch and it didn't work. I think I will have to stay with that low resolution in Windows 3.11, I really have NO idea what is happening... I am pretty sure that card is capable of supporting VESA 2.0 but for some reason I cannot find a driver that handles it.
Thanks for your help.
Reply 7 of 10, by rmay635703
I would attempt to use the 3D Rage Pro Windows 3.1 driver
You may have to mod a few things to force installation but I’ve had good luck on everything from video cards to printer drivers forcing an older driver from a relatedbut older device as the driver
http://vogonsdrivers.com/getfile.php?fileid=497&menustate=0
YMMV
Reply 8 of 10, by dr.zeissler
Rage 3D pro driver does not work for R7000/R9xx0.
R7000 works with WFW256color-drivers
R9xx0 only works with patched vesa-drivers.
Doc
Reply 9 of 10, by rmay635703
dr.zeissler wrote on 2020-11-02, 17:30:
Rage 3D pro driver does not work for R7000/R9xx0. […]
Doc
The r100 is identical to the r7000?
Reply 10 of 10, by dr.zeissler
I think so.
