First post, by patrmich
Hello,
I have old files saved on floppy disks with Winzip under windows 3.1.
Each folder contains dozens of files (often Word or Excel files).
One single folder is saved on several floppy disks (for example a set of 5 floppy disks).
I would like to recover files from these folders.
For this, I bought a floppy disk drive which plugs into USB on my current desktop pc.
When I put the floppy disk n° 1 (1 out of 5) in the floppy disk drive, then I try to open one of the files in the folder, a message asks me to insert the last disk of the set, that is to say the n° 5 (5 out of 5). And it is the same for each file.
So, it takes too long to recover tens of files from each folder.
Would you know how to quickly recover all the files from the 5 floppy disk folder ?
Thank you in advance for any suggestion
Patrick
