First post, by buckeye
I'm in the process of planning to build a DIY computer desk and was hoping to get some ideas from
the fine folks on this forum that might have done the same thing. Basically it's going be sized roughly
30"x 68" and made up of a thick pine? table top with legs or maybe mounted on one of those adjustable
desk frames that are expensive.
I've seen videos of Linus Tech doing some elaborate stuff as well as others where they just used a
"blank" unfinished door and put some heavy duty legs on it. Any ideas, thoughts, pics would be
appreciated, thanks!
Intel SE440BX P3 450 256MB 80GB SSD Asus V7700 GF2 64mb SB 32pnp 350W 98SE
Reply 1 of 2, by BloodyCactus
I built this from 2x4 and some pine board, stained it up. Its half computer desk, half workbench.
Reply 2 of 2, by buckeye
I like it, heavy duty and wide. I'd have to figure up the weight if I mount something like that on those
adjustable desk frames. Most can handle 170lbs. max.
