AT Keyboard Woes
First post, by JLuton
Hello,
This is my first post and I've recently taken on the project to build anold retro machine.
so far I've got all parts and the machine booting but i cant for the life
of me get a working keyboard.
The Motherboard is an ATC-1030 [https://www.elhvb.com/mboards/a-trend/manuals … C-1030/1030.pdf]
The socket is a 5 pin din and the manual states "AT style keyboard connector"
I first got a nice USB keyboard and thought i could use a few adapters, i plugged it into
a USB to PS/2 adapter and then that into a 5 PIN adapter, this Frankenstein creation didn't
work ... so i thought maybe its something to do with the USB protocol.
next i got an older PS/2 keyboard and plugged that into my 5 PIN adapter but this also doesn't
work, its driving me crazy ! I have a built machine but for 2 weeks but cant actually use it without
a keyboard.
Here are some images of the keyboards and adapters i have used.
https://imgur.com/a/EmX8AhR
I've read about XT/AT stuff and think its something to do with this? but im pretty confused
and no closer to having a working keyboard, and all old 5 pin connector keyboards on sale are
a crazy price.
can someone guide me how i can ideally get the USB keyboard working? or at least the PS/2 one.
cheers !
Reply 1 of 9, by vetz
Have you checked the AT DIN connector carefully? I've had motherboards where the AT connector weren't properly fastened to the board (most likely due to shipping/handling damage) and the keyboard would not register. I think every time I tested that by applying pressure on the cable/connector downwards towards the motherboard while I rebooted the system. I then either resoldered the connection or soldered on a new AT DIN connector.
Other than that the PS/2 keyboard should work with that adapter.
Reply 2 of 9, by JLuton
Thanks for the reply,
hmmm, ive taken the board out and cant see any visible signs of damaged, and i've tried applying pressure
but no luck so far
Reply 3 of 9, by cyclone3d
If you want to adapt a USB keyboard to PS/2, it would have to support the PS/2 protocol. I've never tried to go USB to PS/2 to AT but I don't have a great deal of faith that it would work.
Pretty much any PS/2 keyboard should be able to work with a PS/2 to AT adapter.
Have you verified that the PS/2 keyboard is actually functional?
Where are you located?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 4 of 9, by JLuton
ah ok then i will persist with testing with the PS/2 one, i just checked that the keyboard is functional on another machine
so that seems ok, the lights come on and its operational, but with the 5 pin adapter on my other machine nothing happens.
I'm located in the Netherlands. I'm wondering if its a mainboard issue then, hmmmm
Reply 6 of 9, by JLuton
Here is a selection of images,
https://imgur.com/a/HzEo1xi
i dont see any thing obviously wrong with it, i can only think to use a multi-meter to test
the physical connections but i dont own one
Reply 8 of 9, by JLuton
on page 19 of the manual it says PS1 is for a mouse but i will check the fuse,
i need to buy a multimeter soon, meanwhile thanks for the help ! 😀
