First post, by Filosofia
- Member
After watching some 386 build videos I decided to build one and I have this cirrus logic video card . Wonder if it is worth anything or this was common.
BGWG as in Boogie Woogie.
CL-GD542x cards were common as muck. Actual Cirrus Logic evaluation boards possibly less so. Which chip is on it? Do you have pics of the whole card (front, back, slot plate)?
Also: does it work?
it just means they used an example pcb design from cirus and they did not alter it at all
If I saw it for sale, it would be worth €25 to me. Probably more to someone else, as I'm a cheapskate.
Oh ok. Well it works just fine, I'll be pairing it up with an amd dx40. I have two more photos. Let me know if full front and back wanted.
