First post, by jasa1063
jasa1063
Offline
- Oldbie
I recently upgraded my Tandy 1000 TL/2 with a Diamond Speedstar ET4000AX card. Now, I have used the VSWITCH utility in the past, but had to use separate VGA & CGA monitors to do it. I wanted to do the same thing here, but did not have enough room to fit two monitors in the space I have available. I had an MCE2VGA converter I was not using. I purchased a 2 port VGA switch box from Amazon for under $10. I can now use VSWITCH and the switch box to switch back and forth between VGA & CGA with both output sources now being VGA. This should also work with any CGA to VGA converter and it is a real space saver.
