First post, by Grayshazzle
Hello everyone, so for my Windows 98 SE build I was finally able to get this motherboard in the mail today, although I went to take a look at all the pins and whatnot, and noticed a ton of jumpers with different labels around the board itself. I probably don't need to put any pins around flash or on clear CMOS because I will not be doing that but for everything else I am very confused. Also for the 3 pin headers do you put the 2-pin jumper on the right side or the left, does it act like a off or on or something? Also KB Wake and the 66 - 100 confuses me, is it like a serial bus CPU speed thing for oc. Not fully sure about any of this but if I could have clarification that would be awesome, I attached an image to my revision and all with very helpful labels so you all can see what you are looking at. Thanks 😀
