First post, by Kidrash
Hello.
I have a booting M380 but i need the setup floppy to set boot sequence and other things.
Someone can be so kind to send me an image of it?
Thank you in advance.
Kidrash.
Reply 1 of 4, by crvs
Here it is, if I'm not mistaken.
Reply 2 of 4, by Kidrash
Thank you, i try it later and let you know if you saved my life ehehehe
Reply 3 of 4, by Horun
crvs wrote on 2020-11-22, 16:38:
Good find ! That is same file found in the Olivetti archives
http://web.archive.org/web/20150608153917/htt … etti/m380/docs/
Reply 4 of 4, by Kidrash
I tried the file from Crvs and they are for M380 Xp4. I have been able to set most of the things but not the hard drive. In the list it not appears the right one.
Now i will try with the others and see what i can do
