First post, by Mamba
Hello guys,
I am going back and forth with my memory and forum subscriptions (on k6plus as well), trying to find the final answer of the first hunanity question:
Does or does not a properly keyed powerful and bridged AGP card work on a good (let's say P3B-F) motherboard ???
To work I mean in 2D and 3D also.
My findings (with a 6600gt) stated that in 2D it works, but not in 3D.
That said I did not tested a lot of drivers.
Reading here, I saw some people stating they run successfully even some nVidia bridged cards (no NV40) but how?
Is there a particular driver combination or even a modded one?
I am about to receive a Pny 7600GS with 3.3V key to test again.
Can we reach a final agreement?
Reply 1 of 43, by bofh.fromhell
Your 3D problems are almost guaranteed to be driver problems.
Later nVidia drivers don't seem to play well with older OS's and games.
In general try to grab drivers that are only somewhat newer then the games you want to play =)
Reply 2 of 43, by Warlord
Your post is so serious xD. That card should run with the moded 8x.xx drivers. But those drivers might not work with the games you want to play, nevermind 6 series cards lack features present in gf2-3-4-5 series cards. Just becasue some dude on the internet got a gf 6 or 7 card to run on 98se doesn't mean that every game or even a lot of games work.
Reply 4 of 43, by Mamba
Thank you for the replies.
Please do not think about this or that game ok?
Let's not go into the particular case.
It is only a matter of capability here.
Let's keep it simple.
So let's assume that we want to run 3DMark2006 or a 100% compatibile D3D program (or game) on dx9 of course with WinXP.
I know about 56.64 drivers to be the last stable on 440bx, but I saw multiple users who used later drivers.
Please share your experience.
Reply 5 of 43, by Baoran
Wouldn't it be simplest to try the card with another motherboard with same OS and same driver version to see if it is issue with the motherboard or the chipset?
Edit: I was actually going to quickly test it with my 440BX motherboard, but unfortunately my Geforce 6600 is only for 1.5V AGP
Reply 6 of 43, by Mamba
Warlord wrote on 2020-11-24, 08:02:
Can you link to those modded drivers you refer to?
Reply 11 of 43, by hyoenmadan
swaaye wrote on 2020-11-24, 08:08:
Yeah I've found NV drivers after 56.64 to be trouble with 440BX.
For once, I can add 7x.00 driver series don't play well with Aladdin and 440BX AGP northbridges. Tested with mobos I have (Zida and industrial BCMcom).
Reply 12 of 43, by Mamba
Guess I will have to wait a bit and dig myself on finding this combination.
But help would be appreciated from people of this very forum who successfully used any driver above 7x.xx with 440bx and XP (or whant to help).
I read that overheating of the HSI can be an issue for 3D immediate freezing.
Being feeded with 3.3v in this case I see it could possibly be the cause of immediate hang when starting 3D programs.
It is a brainstorming, feel free to share your thoughts.
Reply 13 of 43, by Mamba
Ok I am about to start testing with my 7600gs AGP.
Please feel free to suggest driver versions, even modded, to get it work in direct3D, windows XP.
The platform will be a p2b-d 1.06 with 2x Pentium 933mhz @100mhz fsb to minimize problems.
Reply 14 of 43, by Mamba
All right.
Here preliminary results.
My platform is a P2B-D with 2x Mendocino 500Mhz. (AGENT_007 suggested me to use Mendocino first)
VGA is a 7600GS AGP.
XP SP3
3dMark2001 has completed but with texture corruption, see screens.
Do not know if this is driver related, I started with the latest available.
Results pretty low.
    1.17 MiB
    1.11 MiB
    952.83 KiB
Reply 15 of 43, by pentiumspeed
There are corruptions in these two images.
Switch video card to either 2, 3, 4 or FX 5xxx for a testing.
Cheers,
Great Northern aka Canada.
Reply 16 of 43, by Mamba
pentiumspeed wrote on 2020-12-19, 15:14:
Cheers,
Ahemmm... The pourpose of this testing and discussion is something else....
Did you read the first post at all?
No offense of course.
Reply 17 of 43, by Mamba
Drivers 93.71.
Same texture corruption.
Again a low performance result, even if a bit higher.
It is a texture problem.
Some dx8 features are ok.
Do not know if this is fixable somehow thru nvidia control panel or not.
3Dmark 2003 gives bluescreen after Wings of Glory loading completion (nvdisp.dll error).
    1.23 MiB
    833.69 KiB
    988.1 KiB
    1.37 MiB
Reply 18 of 43, by Mamba
Trying to test a 9800pro but it results in no post at all.
One long beep, three short, VGA issue.
The card of course works in another system.
Strangely, even pci vga (5200 and Rage pro) does the same. VGA error.
Any advice?
Reply 19 of 43, by Mamba
Partial answer to myself.
The Rage pro works. The FX5200PCI is PCI 2.2 and the P2B-D is PCI 2.1, that is why it won't work.
Don'tknow why the 9800pro is not working, maybe it refuse to work with 3.3V even if it is properly keyed, but I remember I used it on a GA-5AX...
In any case, I think I have reached a final answer for this thread, a sad one.
the problem is not the VGA or the motherboard, it is inbetween.
It is the bridge.
For unknown reason there is no support for HSI bridge from AGP 2X chipsets (like 440Bx or socket7).
I do not know if it is an electrical problem but I doubt it, the 7600GS was happily working and was really cold, no overheating.
It is driver related.
Very sad.
If someone wants to add something, would be welcome.
