First post, by jasa1063
I just got this 386/40 computer and would like to know the manufacturer of the motherboard. I suspect it is an American Megatrends 386 motherboard.
It has MB-1333/40 MKA-F Ver:2 printed on it. The BIOS ID string is 30-200-001223-00101111-111192-MXIC-F and the model shows as MB-1340MKA-F on the post screen. The closest match I get is a MB-1333/40 AEQ-K/AEG-K which is an American Megatrends 386 motherboard. Any help would be appreciated.
Reply 1 of 15, by quicknick
Possibly Biostar, judging by the logos on the BIOS and KBC stickers.
Reply 2 of 15, by Horun
quicknick wrote on 2020-11-26, 01:17:
Agree ! The AMI BIOS id is for Biostar and the board logo's/locations also suggest Biostar.
jasa1063 wrote on 2020-11-26, 00:53:
the MB-1333/40AEQ has cache where your board does not, will look deeper after work tomorrow. Yes have to work on Turkey Day but hopefully a short day.
<removed complaint
Spoiler
that Gov workers are underworked and overpaid by our tax dollars but they do not care
Using more descriptive words> 😁
Reply 3 of 15, by jasa1063
Thanks for the help so far and the board is working well. I just want to get a sound card and math coprocessor and I am all set.
Happy Thanksgiving to everyone!
Reply 7 of 15, by jasa1063
Anonymous Coward wrote on 2020-11-26, 16:10:
It has cache. A small one integrated into the chipset.
I figured as much, because when I disabled the external cache in the BIOS setup, I got a noticeable drop in performance. I was going to post that information, but thanks for confirming what I found out. My guess is it probably has 8K-32K cache built in.
Reply 9 of 15, by jasa1063
Deksor wrote on 2020-11-26, 19:57:
You can probably measure that using speedsys 😁
SpeedSys & CacheChk both report a cache size of 8K.
Reply 10 of 15, by jasa1063
The more I research this board, the more interesting it becomes. I can't find much information on the MACRONIX MX83C305FC/MX83C306FC chipset it uses other than it does have an integrated 8K L1 Cache. While that is not a lot of cache memory, I am sure that is partially offset by the lower latency having the cache built right into the chipset for faster memory access. If anyone can point to sources for the datasheets or other info on the chipset, that would be interesting to look at.
Reply 12 of 15, by bloodem
I also found a similar board, although (as far as I can see) there are two major differences compared to this one:
- mine has an onboard CPU, in addition to the external socket (the OP's board does have solder pads for a built-in CPU, though)
- there is no Brand/model information silkscreened anywhere on the PCB.
Other than that, the layout does look almost identical.
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 21 x Slot 1 / 8 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 13 of 15, by evasive
jasa1063 wrote on 2020-11-26, 14:32:
Deksor wrote on 2020-11-26, 08:46:
I confirm this is a biostar.
Unfortunately it's not in our database ... http://www.win3x.org/uh19/motherboard/result/?name=1333
Would you like to help us adding it ?
Sure, let me know what you need.
If you happen to have a different bios version from what is already listed (0200), you can make a backup of the bios with this:
http://cd.textfiles.com/microhaus/mhblackbox3 … MORY/GETROM.ZIP
Reply 14 of 15, by jasa1063
evasive wrote on 2021-05-28, 06:42:
I will check the BIOS this weekend and let you know.
Reply 15 of 15, by jasa1063
jasa1063 wrote on 2021-05-28, 13:23:
The BIOS is 0200 as indicated.
