16bit ISA riser cables?
First post, by tjsnhgaming
Hi all.
Does anyone have a source for a non-rigid 16bit ISA slot riser cable?
Like this PCI riser cable, but for ISA?
https://www.amazon.com/gp/product/B079W8ZMTK/
I'm planning out a case mod into an LPX case (that normally has a fixed riser board to horizontally mount some expansion cards) but for spacing/dimensions reasons it would take a while to get into, I need a flexible riser cable rather than a fixed rigid riser board (presuming I could even find one the right height etc).
Anyone know of anywhere that sells these? They simply MUST exist.
Reply 1 of 1, by cyclone3d
Pretty sure you would have to make one yourself.
See here for an already existing design for the part that would plug into your ISA slot that you can order.
Short on ISA slots? Try this.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
