First post, by peke12
I tried searching for these mainboard drivers but they seem so hard to find.
Without these drivers, I can still install and run Win98, but I get one too many bluescreens.
The system is not stable without them. (I think)
Can anybody help me?
Reply 1 of 4, by Dmetsys
Are you using Windows 98 or Windows 98 SE? The only drivers you need for that motherboard, are the chipset drivers for the AMD 751 chipset.
I have uploaded them to my Google Drive for download: https://drive.google.com/file/d/1HKNWYuM6wJTY … iew?usp=sharing
NF7-S 2.0 | 2500+ @ 3200+ | 9700 Pro | Audigy2 ZS
CUV4X 1.03 | PIII-933 | MX400 | Live! Value 4670
P5A-B | K6-2 450 | TNT2 | AWE64 Value
4DPS | Am5x86-P75 | S3 Vision864 | SB16 CT2290
Reply 2 of 4, by peke12
I'm using Win98 SE.
And thank you. I will test these. It looks promising. 😀
Reply 3 of 4, by Dmetsys
It would also be best to perform hardware diagnostics, to ensure that you don't have bad RAM, hard disk, or some other point of failure. Is your power supply an old 20-pin variant? Are the capacitors bulging? Blue screens could mean anything, when not properly diagnosed. Slot-A is also a very power hungry platform, and requires a fair amount of amperage on the 5V rail.
Reply 4 of 4, by peke12
Dmetsys wrote on 2020-11-29, 19:23:
I'm using a 350 watt psu 20-pin variant. The 5v rail has 32A.
