First post, by script-fu
I am currently stuck on whats the best processor for the abit Fatal1ty AN9 32X AM2 motherboard.
It says (BIOS: m601b19.zip) ID:19 Update CPU Micro code to support Athlon 4X50 series and Sempron X2 CPU.
http://abit.ws/page/en/motherboard/motherboar … &pPRODINFO=BIOS
What in the heck is a Athlon 4x50?
I have a AMD Athlon 64 X2 3800+ 2.0GHZ Socket AM2 Processor in this motherboard ATM. I am also on the REV 14 Bios however the computer has no idea what processor i'm running ATM.
I am also kinda freaked out about updating the bios as the instructions on the abit website are missing the photos.
Gb GA-6BXC r.2.0 b.F4C, PIII 1.0GHz SL5QV, 768MB PC133, GF Ti 4200 64MB, VD3 2K, CT4760 & CT4860 AGP 2X
Abit KN8, 64 3400+ (754), 2x1GB G.SKILL PC3200, GF 6800GT 256MB AGP 8X
Abit Fatal1ty AN9 32X, 64 x2 6000+, 2X2GB PC6400, 8800 GTS 320MB x2 SLI
Reply 1 of 8, by pentiumspeed
AM2 means you can use up to Phenom II, use X2 or X4 but this being DDR2 cripples you to 8GB but perfect for XP with 4GB.
Cheers,
Great Northern aka Canada.
Reply 2 of 8, by script-fu
Okay pentiumspeed I have a (AMD Phenom II X4 955 Black Edition) here. It's says it's an AM3 CPU. My motherboard is AM2 only. Not AM2+ so this is throwing me a bit. How could a AM3 CPU work in a AM2 only board?
Reply 3 of 8, by quicknick
AM3 CPUs support both DDR2 and DDR3 and they can work on AM2 boards provided there is BIOS support.
Socket AM3 processors are able to run on Socket AM2 and AM2+ motherboards with appropriate bios updates, but not vice versa. AM3 processors have a new memory controller supporting both DDR2 and DDR3 SDRAM, allowing backwards compatibility with AM2 and AM2+ motherboards. Since AM2 and AM2+ processors lack the new memory controller, they will not work on AM3 motherboards.
(Wikipedia)
Reply 4 of 8, by pentiumspeed
Yes, that correct, I had phenom II x2 on am2 motherboard at one point. No problems.
Also, if you want 16GB on DDR2 (which what AM2 through AM3 processors are all onboard memory controller are, including ECC support, verified by me), look for AMD supported DDR2-800 4GB modules. Does work, but the motherboard I had was microatx asus based AMD 785G chipset died. Later research revealed that 785G had high failure rate. So I'm waiting for time to purchase board with reliable chipset and DDR2 to rebuild my oddball DDR2 16GB machine.
What chipset do you recommend for AMD chipset using AM2 or AM3 with DDR2 board? one of these FX type?
Cheers,
Reply 5 of 8, by bakemono
script-fu wrote on 2020-11-29, 20:32:
I am currently stuck on whats the best processor for the abit Fatal1ty AN9 32X AM2 motherboard. […]
Probably means the Athlon 64 X2 4050, 4450, 4850 lower power versions.
That page doesn't say anything about Phenom support, does it? On AM2 boards that support Phenom 1, some Phenom II CPUs will usually work because of how close they are (even if they aren't officially supported) but if it doesn't support Phenom 1, then Phenom II has no chance. (Of course, boards with only DDR3 will support Phenom II but not Phenom 1, but that is a different thing)
Also, some Phenom II CPUs require dual power planes and will boot at only 800MHz in socket AM2. Athlon II X2 doesn't need dual power planes.
GBAJAM 2024 submission on itch: https://90soft90.itch.io/wreckage
Reply 6 of 8, by script-fu
bakemono wrote on 2020-12-01, 03:22:
Probably means the Athlon 64 X2 4050, 4450, 4850 lower power versions. […]
Nope not a word about Phenom. Even the CPU table doesn't say a thing. I don't even think they were released by the time abit went belly up.
Thanks!
Reply 7 of 8, by The Serpent Rider
Abit, MSI and many other vendors had never implemented Phenom support on their Nforce 5 series motherboards. You're stuck with Athlon 64 X2 6400+ as best possible option.
They were released when company was still alive. Last boards which Abit designed were based on X58 chipset, although they didn't showed up in retail, but some are there in the wild. Apparently they've also made X48 and P45 boards, but in very low quantity and possibly very raw BIOS.
Reply 8 of 8, by script-fu
Well well well nice link man on the Abit IX58-MAX!
thx
