First post, by bloodem
- Oldbie
Today I decided to play with one of my 430TX/Pentium MMX 233 MHz PCs, and encountered a very weird issue with Prehistorik 1: the game works fine until you get to the second level, at which point it freezes at the "Please wait while loading level 2" screen.
Initially I thought it might be related to sound, so, of course, I tried various sound cards (both ISA and PCI), but nothing worked. Then I also tried without a sound card (and no sound setting) --> same problem.
I then tried various speed settings with setmul, changed the CPU multiplier --> same problem.
Tried different SDRAM and EDO sticks --> same problem
After that I tested a few different video cards (S3 Virge DX, Matrox Millennium II, Riva TNT, Riva TNT2 M64, Voodoo Banshee, Voodoo 3) --> same problem.
Eventually I just gave up and assumed that this particular motherboard (Zida 5DTX) is fussy when it comes to this game, so I tried another Pentium MMX PC (with an iWill P55XUB motherboard & same 430TX chipset). I couldn't believe it when I saw that this motherboard has the exact same problem. I then tried another motherboard, the Acorp 5TX29 (again, 430TX) --> same problem.
As it stands, I'm all out of ideas. Anybody know of a miracle solution to this problem? To me, a DOS PC is as good as trash if it can't run Prehistorik 1 properly 😁
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 14 x Slot 1 / 6 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
