First post, by igna78
Hello everyone, I'm looking for help finding an upgrade for the video memory of an IBM 2133-540 PC. The video system is based on a CL-GD5424 video chip with 512K of memory, expandable to 1MB via 512K expansion over 40pin zif. Any idea how / where to find this component? Thanks everyone for your time
Reply 2 of 9, by igna78
As requested, here are some images of the motherboard with the detail of the insertion socket for the expansion of the video memory
The attachment IMG_8639.jpg is no longer available
The attachment IMG_8640.jpg is no longer available
As I said I am looking for the 512K video expansion .. I have no idea where or how to look, so I thank anyone who wants to help me in my research 😀
Reply 3 of 9, by igna78
Any idea?
Reply 4 of 9, by Caluser2000
Google is your friend...
Reply 5 of 9, by cyclone3d
I think this may be what you are looking for:
https://www.ebay.com/itm/UPD424260V-70-V20-25 … -1/153203289210
Your board looks like the soldered on chip is 60 ns but these I found are 70 ns so not 100% sure it will work.
Just for future reference, that style of chip is called ZIP.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 6 of 9, by igna78
Thanks for the help ... actually the soldered chip is 80ns so I hope adding a faster one will work
Reply 8 of 9, by retroegde
I know this is dated by I found this when searching for information on my IBM 2133-23c. I've been able to successfully upgrade the video memory for the CL-GD5424 on my IBM 2133-23c and 2155A-24C PS/1 computers. I soldered an additional chip in the available pads. @Epictronics1 on youtube has a video on this upgrade. Just be careful in the tight space with your soldering iron!
Reply 9 of 9, by c3688t
I know this topic was closed a long time ago. Forgive me, I'm brand new to the site. Trying to do an upgrade of a PS/1 2133 M40 with 486sx and CL-DG5424 graphics chip. Like yours, my motherboard has one 512kb soldered down and a second set of pads / outline for second memory chip. Curious if you had to add any surface mount resistors / caps to make your motherboard recognize the second dram IC or if it just found it automagically? Any issues worth sharing since you added yours? BTW the ram on mine is NEC 42S4260-80. I can't seem to source an exact duplicate, but I'm sure I can find an equivalent. I think it's a 256k x 16bit. Thanks for anything you can share.
