First post, by AntiRevisionism
I'm moving my Athlon 64 3400+ machine components into a modern case. The motherboard is mATX, so the case is quite roomy. Even the really long (for it's time) Sapphire 3850 AGP card fits without any trouble.
What's throwing me off is that the power supply is bottom mounted in this case. Which direction should the PSU fan be facing? Upwards (into the case) or downwards (out of the case)? Does it make any real difference?
Reply 1 of 6, by debs3759
Power supplies can normally only be fitted one way, as the holes are not symmetrical. The fan should be facing upward if it conforms to normal standards.
Reply 2 of 6, by cyclone3d
Cases with bottom mounted PSUs like that are meant to have the PSU fan pull in cool air from below the case.
This way, the PSUI stays as cool as possible which also has the added benefit of making it last longer than if it were pulling warm air from outside the case.
To top it off, a newer case like that will have enough airflow through the case to keep everything else a lot cooler than an older style case. No reason whatsoever to have the PSU cool itself with warm air from inside the case.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3 of 6, by pentiumspeed
Always insure the PSU fan blows out of the case, you don't want heat blown at the CPU. Silly.
Cheers,
Great Northern aka Canada.
Reply 4 of 6, by pete8475
debs3759 wrote on 2020-12-05, 23:17:
Modern cases typically have two sets of mounting holes so you can mount your power supply in either orientation.
cyclone3d wrote on 2020-12-05, 23:25:
100% agree.
aka pete4237.5
Reply 5 of 6, by Horun
pete8475 wrote on 2020-12-06, 02:14:
Modern cases typically have two sets of mounting holes so you can mount your power supply in either orientation. […]
100% agree.
Agree that the particular case in the pictures is designed to have the fan aimed at the bottom,
but not all cases with bottom mounted PSU are designed to have the fan pull air from below the case, have one or two that have no vents below the PSU so the fan has to mounted pointing up or toward the front, depending on the PSU design...
Reply 6 of 6, by AntiRevisionism
Indeed, this is what threw me off, as this Rosswill case has two sets. ( https://www.amazon.com/gp/product/B01IT0TDY6/ ). I've since mounted it with fans facing downwards out of the case.
