First post, by Lawrence Shadai
Hello everyone !
I'm new here after lurking for many years getting answers I need from time to time.
Due to a personal pet project I have had a chance to test and use a great deal of productivity and utilities on DOSBox. For some programs I have found viable workarounds as well. I even found a way to get "New Deal Office" to run on the stock Debian and Ubuntu installations of DOSBox.
How should I submit what I learned to the lists ?
Lawrence.
Reply 1 of 4, by Cyberdyne
you have better luck with Dosbox-X forum, because bare Dosbox (forever and ever version 0.74 pun intended) is only officially for games. But you are welcome to post your findings here, and it is a good thing that someone is experimenting with other stuff that can run in Dosbox.
Reply 2 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
You can just create an account on the site and add stuff to it ?
If a productive tool works, then great!
Water flows down the stream
Reply 3 of 4, by Lawrence Shadai
I've actually had a ton of luck with productivity tools to the point where I am actually using them again on a regular basis.
Yes, I am sharply aware that DOSBox was never intended for non-gaming, and I have zero expectation that the community will make provisions for non-gaming software that does not enhance gaming support.
In fact, for some major productivity packages, it is downright excellent as it is.
L. Shadai
Reply 4 of 4, by Lawrence Shadai
I should also mention:
In my not-exactly-sane experimentation with productivity apps I also got the following very old CP/M-80 games for the Kaypro II/2/4 series to work in DOSBox. I am wrapping up final testing and am willing to write a simple step-by-step guide to get each one working in DOSBox. As of now the games Ladder and Zork I,II and III are working and the config program for Ladder works as well.
L. Shadai
