First post, by Grayshazzle
Hey all, I just got this card and and saw two jumpers placed onto the board in a certain location that has some white around it signaling that it basically would go here. What does this even do as a setting and is it a factory standard for this card? My model number is different but the same principles of the card are there along with the functions. Thanks.
Reply 1 of 4, by Joseph_Joestar
That entire header is meant for the corresponding front panel device, one of these:
The attachment ZS_Front.JPG is no longer available
You're not supposed to put any jumpers there, it's where the ribbon cable leading to the front panel connects to.
Reply 2 of 4, by chinny22
By pure chance SScorpio just answered your question in a similar post!
Auzentech Prelude 40 pin header uses?
Note at the bottom says jumper across 25-35 tricks the card into thinking you have a front panel like the one above, not sure why you want want to though?
Reply 3 of 4, by SScorpio
chinny22 wrote on 2020-12-09, 09:57:
If you aren't connecting anything else to the card, there's no reason to. But the jumper does enable some inputs which are disabled without an Audigy Drive connected.
Reply 4 of 4, by Grayshazzle
Thank you guys 👍
