First post, by Doornkaat
Hey, everyone! 😀
I just noticed my AOpen AP5T Rev. 3.5 has a weird spot that looks a bit like a homemade rework but then again it's pretty clean so I don't know what to make of it.
I googled for pictures of the board and found that Rev. 3.1 has a resistor at R400 while my Rev. 3.5 has this hand soldered looking solder bridge and an IC at U31 where my Rev. 3.5 has only got empty pads.
From an angle the bridge looks like it there's a very thin piece of metal underneath all that solder too. There's also a bit of flux residue underneath the solder bridge that seems to have spilled onto the pads of U31.
Otherwise the revisions look very similar.
Now I'm wondering wether this is a factory rework or if some previous owner just removed the IC and bridged R400.
Does anyone have another Rev. 3.5 board to compare?
Thank you for any feedback! 👍
    105.56 KiB
    116.47 KiB
Reply 1 of 9, by pentiumspeed
Normal. The solder blob is because the pads is made to be shorted depending on options.
8 pads is for a sub-regulator feed back IC to regulate the main high current regulator.
Do not worry about that, this is original.
Cheers,
Great Northern aka Canada.
Reply 2 of 9, by Doornkaat
pentiumspeed wrote on 2020-12-12, 16:55:
Normal. The solder blob is because the pads is made to be shorted depending on options. 8 pads is for a sub-regulator feed bac […]
Cheers,
Hey, thanks for the quick reply! 👍
Any thoughts on why the sub-regulator feed back IC was implemented in the first place?
Would you expect dropping the IC (since it was present on an earlier revision) to be a cost cutting measure or do you have any other theory?
Reply 3 of 9, by pentiumspeed
Depends on needs. IC is more precise, adjustable and can use higher current regulator than the complex low dropout regulator usually found on higher quality motherboards. Acer/Aopen is not known for quality.
Don't need to overthink over this. 😀
Cheers,
Reply 4 of 9, by Doornkaat
Thank you again for the explanation!
However I can not agree with
pentiumspeed wrote on 2020-12-12, 19:03:
for this generation of hardware when Anand Lal Shimpi was full of praise for AOpen boards back in the late 90s and my personal experience with them is 100% positive.
Doesn't mean I'd buy Acer today though.😉
Reply 5 of 9, by Deksor
Would you like to upload a nice photo of your board to improve our page here ? http://www.win3x.org/uh19/motherboard/show/188
Reply 6 of 9, by pentiumspeed
Back in the day, we worked on Aopen and Acer stuff and they were not same level of quality as big names like ibm, compaq etc. Even compared to Asus, they were lesser quality and frequently has quirks.
Cheers,
Reply 7 of 9, by Doornkaat
Deksor wrote on 2020-12-13, 19:24:
Yeah, sure. I was planning on seeing what else I could contribute anyway.
The page you linked to is for Rev. 3.0 while my board is Rev. 3.5.
Should I upload my pics anyway?
Reply 8 of 9, by Deksor
Yes ! We'll figure it out (actually the rev numbers you see on here are manual revisions, not board revision)
