First post, by user222
If you try to start "NoteWorthy 2", you will get this error message: (see picture)
Download the trial version from
[http://www.braeburn.co.uk/nw2inst.exe]
    10.45 KiB
Reply 1 of 5, by MiniMax
Rank Moderator
Moderator
Did you try the obvious? Create a dummy C:\CONFIG.SYS with a dummy FILES=20 ??
_________________
Reply 4 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
a very bad call.
http://www.delorie.com/djgpp/doc/rbinter/id/06/44.html
Not sure if we want to support that one.
Maybe clearing the carryflag would be enough
Water flows down the stream
Reply 5 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
clearing the carryflag is enough:
    8.45 KiB
    proof
