S3 Trio64 not POSTing
First post, by injurer
Hi. I'm new here. Recently I decided to remove the dust from some old hardware and make a retro build.
I have an 586TX motherboard with an S3 Tri64, and a Cyrix CPU. I cleaned everything, repasted the CPU and plugged it to an old PSU. Now I hooked this test bench to a relatively new 1440x900 LCD monitor.
After starting it, for a brief moment I can see the S3 VGA BIOS message, and a second after the monitors turns off telling the the signal is out of range.
Now I'm unsure if it's due to the monitor incompatible with the resolution the S3 card is trying to push, or the problem is related to something else.
Any help or suggestions are appreciated how to diagnose the issue.
P.S. Any chance I can plug a USB keyboard? I don't have an old DIN-type one. Are there any adaptors available?
Reply 1 of 6, by kixs
Old hardware is for old hardware. I'd recommend a CRT monitor.
In this case I think the S3 is trying higher frequencies. What make/model/brand is the VGA card? Does it have any jumpers?
Reply 2 of 6, by debs3759
Is your modern monitor fully VGA compatible? Does it work with other VGA cards?
Reply 3 of 6, by red-ray
injurer wrote on 2020-12-14, 13:55:
On my old systems I have seen this for a few GPUs when Windows 9X starts, rarely for Windows NT/XP and never while the BIOS is posting. I can't remember which GPUs I was using as I have quite a lot and when it happens simply use a different one. I have not had any CRTs since around 2001 and as yet have never had any real issues with using an LCD display.
I usually use my Dell 2007FP or Dell 2407WFP which support most resolutions from 640 x 480 up to their maximum, what does your monitor support? Do you have any other monitors you could try?
file.php?id=98187
Reply 4 of 6, by injurer
Thanks for all the replies. No, I don't have a CRT and honestly I dont wanna get one. I will try another monitor. The one that I am using is from quite an unknown brand Emperex LM-1905, and no, no any jumpers on it. I will update the post once I find something.
Reply 5 of 6, by kixs
I meant what is the brand of your VGA card - you can also post a photo of your card.
Reply 6 of 6, by injurer
I tried another card and have the same issue. So it is either the monitor or the mobo/CPU.
