First post, by DaveJustDave
this was one of those incoherent late night ebay purchases. I picked up one of these and when it arrived i realized my mistake.
Would it still work in DOS 6.22 on a 286 class machine? I would just need some drivers from adaptec ez-scsi? or would it not work at all?
It's been a few years... I think i need aspi2dos.sys, not sure if I need any other drivers, or if I will need afdisk to partition the drive.
I have no clue what I'm doing! If you want to watch me fumble through all my retro projects, you can watch here: https://www.youtube.com/user/MrDavejustdave
Reply 1 of 12, by darry
DaveJustDave wrote on 2020-12-22, 04:42:
this was one of those incoherent late night ebay purchases. I picked up one of these and when it arrived i realized my mistake […]
Without a SCSI BIOS, you won't be able to boot from any device (like a SCSI hard drive) connected to it .
Reply 2 of 12, by Warlord
those are for windows only for like hooking up scanners
Reply 3 of 12, by Vynix
They'll work just fine but obviously you won't be able to boot from a SCSI HDD connected to this card.
Reply 4 of 12, by douglar
Is it feasible to add a Bios to the card?
Reply 5 of 12, by maxtherabbit
It will work perfectly fine in DOS on a 286. You do need ASPI2DOS.SYS. You will also need ASPIDISK.SYS for HDDs and ASPICD.SYS for CDROMs. You will not be able to boot from the SCSI hard drive.
Reply 6 of 12, by DaveJustDave
that makes a whole lot of sense. it hadn't occurred to me that I'd need BIOS to boot - duh! I ended up ordering the BIOS version of that board, $20 mistake after shipping. I guess that's not terrible but now I have this paperweight on my desk.
Reply 7 of 12, by Errius
So it's missing the boot ROM and floppy controller?
"AI Requires Proof That You Are Human"
Reply 8 of 12, by Horun
Errius wrote on 2020-12-22, 17:54:
Yes ! It probably came with a SCSI CDROM, JAZZ drive or higher end SCSI scanner.
Added: The 1510 is a stripped down 1522 (it had BIOS and Floppy support), both use the AIC-6360
Reply 9 of 12, by Caluser2000
DaveJustDave wrote on 2020-12-22, 17:47:
You can still use it. Just not as a boot device scsi card.
Reply 10 of 12, by debs3759
It doesn't need a floppy controller as there is no floppy connector, only internal and external SCSI connectors.
Reply 11 of 12, by led178
The attachment IMG_20211005_095206.jpg is no longer available
I am using a board to solve the 2000 problem 😀 Also bios can be added using a network card.
Reply 12 of 12, by dionb
douglar wrote on 2020-12-22, 15:06:
Very. Take a look at the delta between the AHA-1510A and the AHA-1520A. All the silkscreen and connections are there for the missing bits on the AHA-1510A. Some are SMD though, so it takes a steady hand and the right tools, but very much within the realms of ability of someone who's done something like the Lo-Tech 1MB/2MB EMS memory boards.
