First post, by Whoo71
Hi All,
I picked up an old 286 last summer and have recently found some time to debug it to try and get it running (as it will not turn on). After finding nothing on Google or archive.org aside from this thread covering the same issue on a similar machine, I can conclude that there seems to be very little information on these machines.
I have yet to do any testing with a spare AT Power Supply to test the mainboard, but judging from the state of the power supply in it I'd say that it's a likely the culprit:
341.82 KiB
GPL-2.0-or-later
271.27 KiB
GPL-2.0-or-later
88.45 KiB
GPL-2.0-or-later
I've done some preliminary testing of components, during which I found:
  • All resistors appear to be faulty, reading ohms well below what they're rated for
  • Both diodes on the board appear to be shorted (~.6V in one direction, >2V in the other)
  • The fuse isn't broken
So at this point I'm thinking my only option would be to replace every component in it, as it seems like there's a lot of stuff that's gone bad. However, I'm not sure how I would source certain components in it, like the transformers (which look like they may be the source of that residue all over the board?). Does anyone have any thoughts on going that route? Or would it be better to cut my losses and see if I can find a similarly sized AT power supply and stuff it in the enclosure here?
And for those interested in the system itself (as it sounds rare judging from the thread I linked), here are some pictures of the mainboard and the case:
1.11 MiB
GPL-2.0-or-later
240.2 KiB
GPL-2.0-or-later
Reply 1 of 3, by andrea
Whoo71 wrote on 2020-12-22, 05:11:
That's a Delta, it means quality. Worth repairing imho.
Have you testing in circuit or out of circuit? In circuit of course you are going to have stuff in parallel leading to lower resistance and other weird stuff.
Isn't that just leftover flux with maybe a hint of cap juice?
It would probably be the quickest way, yes, but keep in mind most older PSU (except name brand stuff, like Delta, Astec, LiteON, FSP...) were mostly garbage.
I'd say test the caps, especially the small ones that can prevent the psu from starting at all, and see how they are. Also,
I can't tell, is it just a reflection or does that 6 pin DIP have a crack in it?
Reply 2 of 3, by Whoo71
andrea wrote on 2020-12-22, 09:43:
It was in circuit, so yes that would likely be why I was seeing those numbers.
Does flux tend to turn that dark brown color in systems this old?
I did also remove capacitors where there was a huge concentration of the stuff:
1.91 MiB
GPL-2.0-or-later
It was also up on the legs of some of the capacitors, so that would suggest that it's leaky capacitors that caused that residue. I'd think there would be way more corrosion though; the only corrosion I can see on the board is on the screws for the MOSFETs. Regardless, I think I'll re-cap the whole board and give it a good cleaning to get that stuff off.
Looks like it's just the reflection.
Reply 3 of 3, by andrea
Whoo71 wrote on 2020-12-24, 06:01:
Ah no, that's just 100% capacitor. Clean the board, recap, and see what happens. Probably it'll start working.
