First post, by Kaisersoze
Hi guys,
as written in the title, i would know if is it possible to modify ( lower, to be more precise ) the multiplier on this mobo. And, if not, what could i do.
Thanks in advance
Hi guys,
Thanks in advance
Please guys, i'd appreciate a lot some tips from you
Sorry, but i'd like more exhaustive tips beyond a simple user manual that i have read YET.
I just know that i can't modify the multiplier simply through bios setup, but i should do it by jumpers way ( and i won't open my case every time i need to mod it ). So, according to my version of mobo, i would acknowledge if it could depend on a limitation from my mobo/CPU, or on the bios version ( need upgrade? ).
Following these aspects, is it possible to lower it via software ( f.e. CPUID )? All this stuff 'cause i would use my new old machine also for msdos gaming purposes.
Now, i hope to be more accurate about my help requests.
Thanks in advance.
Never used this, but maybe it helps:
SetMul - Multiplier control for VIA C3 / AMD K6+7+8 Mobile / Cyrix 5x86
quicknick wrote on 2020-12-27, 13:37:Never used this, but maybe it helps:
Mmm...already thought about that, but i don't think that setmul would be able to do something to amd desktop cpus like mine, much less i won't adopt real-time solution that could make my rig unstable, or at least i'd consider these methods as a last try of sort.
Honestly i was hoping that someone among you would have familiarity and experience with that type of mobo.
Phil's got you covered. https://www.youtube.com/watch?v=K5vYD0JMD_A
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
Ok, got some good infos about my mobo and how i can work on it.
Just another question: could you suggest me where can i find the last bios rel for my motherboard?
It seems that Acorp is dead at all and from google i had bad luck...
Here is what i've found till now ( December 23, 2002 ver 1.1 - file name 7kta3v11.zip )
There's a more recent BIOS on wimsbios, but it doesn't say what version it it. https://www.wimsbios.com/biosupdates/acorp/6A6LMX34
BIOS Release date: 2004-09-29
debs3759 wrote on 2021-01-03, 21:35:There's a more recent BIOS on wimsbios, but it doesn't say what version it it. https://www.wimsbios.com/biosupdates/acorp/6A6LMX34
Sorry but the link you posted readdresses me to biosagentplus.com which wants me to register ( and PAY )
Sorry, didn't realise wimsbios were another phishing site.
debs3759 wrote on 2021-01-03, 23:23:Sorry, didn't realise wimsbios were another phishing site.
Never mind. I think i'll give a try on what i've on my hands ( 1.1 ver ). Then, i'll try to apply a xp-mobile cpu in order to verify if setmul can help me.
GPU: i would mount a gef ti 4600 as primary card ( Win98 env ) through AGP, a V2 SLI for 3DFX games, and a s3 virge as second GPU via PCI in MSDOS switching between AGP/PCI through bios in case i want to start on Win or DOS, ( i'm gonna mount a second hdd apart that i should use only for MSDOS purposes, as in bios i could alternate hdds detection ).
For what concerns the audio management, i would take advantage of the AC97 onboard since i noticed on this forum that it should be fine even with soundblaster emu ( even if i've already bought a ct2800 vibra16 with opl3 yamaha genuine chip in case of troubles since the mobo has an ISA slot which i could use )
Basically i would realize an allround machine capable of running games from early 90s ( setmul help me plz ) to early 2000s.
