First post, by Caluser2000
As the title suggests this thread is for XT Turbo class 8Mhz to 10Mhz systems.
Mine is a Redstone Computers 10Mhz with a PIM-TB10-Z mobo, 640k of ram, TVA EGA monitor and card, XT-IDE 8-bit isa card with a 2gig Big Foot hdd, enhance XT class keyboard, DFI three button mouse that can be switched to two buttons when/if needed, along with both high density 3.5" and 5.25" floppy disks drives as well as a network card and Amstrad Adlib clone sound card. A has IBM Dos 5.02 , Geoworks Pro 1.2 and some other Dos software loaded on it. On boot up it loads a Dos mouse driver and boots directly in to GeoWorks. This is faster than booting MS Windows 3.x on a 386SX25 system.
Reply 1 of 5, by keropi
nice!!
I am still running this system here: Hyundai SUPER-16TE xt clone: restoration and info
the only change is that I now have a NTSC 1084 monitor so I get color cga digital/composite on the same screen 😀
Reply 2 of 5, by Caluser2000
keropi wrote on 2020-12-24, 22:28:
nice!!
Well done!
Mine also came with the original User Guide and 10Mhz mobo User's Manual.
Reply 3 of 5, by sledge
My PC XT "turbo" clone
NEC V20 / 10MHz + Intel 8087
late XT-clone MB (more or less similar to JUKO BABY XT BXM)
640 kB RAM
HDD: Lo-tech ISA CompactFlash Adapter + 2GB CF card
3.5" FDD and Gotek
Video Seven (V7) VEGA VGA 256kB
Sound Blaster 1.5 CT1320C
3com Etherlink II with AUI/RJ45 transceiver
(all expansion cards are 8bit ISA, to keep it "pure" 😉
You can see it running CheckIT here (it's the left one):
The attachment Ep2mieiXcAQ__Ao.jpg is no longer available
doshaven.eu / high-voltage.cz
Reply 4 of 5, by Horun
I have two: A Pacific Computer Systems Turbo XT luggable with original DTK PIM-TB10 mobo
and a Laser XT/3 with original keyboard, original 360k and 720k floppies, and manual. Swapped the dead HD with a WD 200Mb SCSI HD on a Data Cannon SCSI adapter.
Luggable: Re: What retro activity did you get up to today?
Laser XT/3, am using a Dell 1908FP LCD monitor on it.:
Reply 5 of 5, by wiretap
DTK PIM-TB10-Z with 10MHz 8088, ATI VGA Wonder 16, Adlib clone, XT-IDE, 5.25" 360k floppy.
My Github
Circuit Board Repair Manuals
