First post, by cheeseman
well i keep going this error message. Specifically, i run the setup program and this comes up after saving and exiting, and i cannot start up war.exe either as it tells me i need to run setup.bat first. I have searched these boards, but there is so much to sort through it was hard to find anythign relating to this, can anyone help me?
    77.71 KiB
Reply 1 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
yes. We fixed it in the current code.
you can try a different version of warcraft. not all versions are affected.
else you can use dos32a look at that break through in the top of this forum.
Water flows down the stream
Reply 4 of 4, by MiniMax
Rank Moderator
Moderator
Like this?
http://dosbox.sourceforge.net/wiki/index.php?page=dos32a
_________________
