First post, by mike_canada
Ok, so I am running DOSBOX on linux with webserv downloaded for DOSBOX from rubbermallet.org and sometimes it serves pages fine to my linux browser and other times, I get reported "connection reset by peer" messages.
I borrowed DOSBOX networking ideas from this url:
https://www.dosbox.com/wiki/Slip_configuration_on_linux_host
and I changed baud rate setting from 9600 to 115200 and for slattach and socat, I added the -v option to see all network activity between DOSBOX and linux
As activity happens, I see a date and time stamp along with the number of bytes that got passed along with data. When I look at the raw log, it looks as if all the data has been sent from DOSBOX because I see the closing HTML tag which is what I always add to the end of my HTML webpages that I create.
If I use linux curl to access some of my pages (which DOSBOX already produced HTML output with correct headers), I see only the correct headers show up and receive the following error:
* Recv failure: Connection reset by peer* Closing connection #0curl: (56) Recv failure: Connection reset by peer
Attempting the same page gives me a less helpful answer in Seamonkey browser:
Connection InterruptedThe document contains no data.The network link was interrupted while negotiating a connection. Please try again.
The only thing I can think of is that a certain byte or set of bytes are being passed between DOSBOX and linux and one of linux's utilities (socat and/or slattach) is converting those set of bytes to data that indicates premature ending to the HTML to linux yet the logs from those utilities (from using the -v switch to both) show full HTML has been received.
Why do I suspect this? because I remembered when I was outputting data to the serial port in linux one time to an actual piece of hardware connected to the serial port, the data wouldn't flow because I was using character codes 10 and 13 which I later found out online was software flow control.
Could there be a better way of setting up a network between linux host and dosbox so dosbox has access to internet and that linux won't take a sequence of characters as if the data is supposed to end when it shouldnt?
