win32 installer?
First post, by Guest
ok
I've just downloaded the latest version of dosbox so I can play tyrian 2000, (I'm running wondows XP). Apparantly I need a win 32 installer to install dosbox. Can anyone tell me where I can get one?
Thanks
Reply 1 of 3, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
If you downloaded the Windows version version of DOSBOX (it is a runnable - EXE - file), then just run it (it is the installer!). You do not need anything else.
Mirek
Reply 2 of 3, by guest
What if I downloaded doxbox for the mac?
When I tried running a game, it said "this program must be run under win32."
Can you help?
