First post, by Miphee
Coppermine core CPUs go up in smoke within seconds without a heatsink but what about Tualatin core CPUs?
I want to buy a few untested Tualerons and I'd like to know it they have overheating protection or not.
Reply 1 of 27, by debs3759
I wouldn't expect them to last long without a heatsink.
Reply 2 of 27, by Miphee
If it has thermal protection then the CPU will shut down to prevent damage. For example it's impossible to simply cook a s775 Celeron as it will shut down when the core temperature reaches a certain point. But was this technology used in Tualatin core CPUs? These have a metal heatspreader so you can't really tell by looking at it.
Reply 3 of 27, by Errius
https://www.youtube.com/watch?v=yRn8ri9tKf8
PIII freezes if it overheats. P4 slows down. Both cases CPU unharmed.
"AI Requires Proof That You Are Human"
Reply 4 of 27, by Horun
Miphee wrote on 2021-01-01, 03:14:
NO ! all soc 775 had good internal thermal shut down. Not the same as a soc 370 (basically none) and P4's which had limited.
Your Intel Tualatin has no internal thermal shutdowns AFAIK, fried a few P3 soc370 because of heatsink failures.
They were far worse than AMD Socket A for thermal death.... just my experience and opinion..
I do not care what that Utube shows. WHy because they halted the Intels as soon as the video monitor showed artifacts but kept the AMD running,,,
hmmm not a fair comparison as I know that p3 soc370 would be dead if they let it go the same amount of time.
Reply 5 of 27, by Miphee
It's convincing but I burned a Celeron 700 a few years back because I forgot to install the heatsink and the CPU core cracked.
Did it again to a Celeron 600 because I was too lazy to install the heatsink and I just wanted to see if the diagnostic card recognizes it. It was on for a second and it was enough to kill it, smelled really bad.
I just don't trust "untested" but don't want to miss out on good deals.
Maybe the heatspreader is enough to protect the core a little better.
Reply 6 of 27, by Miphee
Horun wrote on 2021-01-01, 03:29:
Yup, did the same thing and all it took was a second and the chip died.
I just don't want to buy yet another faulty CPU sold as untested. Too bad 90% of sold CPUs are untested here. 😒
Reply 7 of 27, by kolderman
Oh yes. As do their contemporary socket A cousins.
Reply 8 of 27, by Miphee
Too bad I can't find a picture anywhere that features a burned Tualatin with the heatspreader on. (discolorations, burn marks, anything).
So it's a hit or miss game but that's what untested is all about.
Thanks guys.
Reply 9 of 27, by The Serpent Rider
PIII overheat protection relies on how fast motherboard can react to temperature increase. Exposed cores have higher chance of frying, especially the ones with higher TDP. Tualatin has IHS combined with lower TDP, so motherboard has enough time to react.
Reply 10 of 27, by Miphee
Thanks, I've decided to risk it because I need these Tualerons for my collection.
Reply 11 of 27, by debs3759
Is there any reason you don't want to use a heatsink and test them safely?
Reply 12 of 27, by H3nrik V!
debs3759 wrote on 2021-01-01, 18:32:
As in it would be pretty easy just to place a loose heat sink on top of the cpu if it's placed horizontally?
Reply 13 of 27, by mkarcher
Errius wrote on 2021-01-01, 03:23:
PIII does nothing by itself when it overheats. But PIII has an integrated temperature sensor, which can be read by a sensor interface chip on the mainboard. The processor itself does only expose the raw analog sensor to some pins, so there is no way you can directly read the temperature from code, you need the external analog to digital converter to know the processor temperature. If you use a suitable mainboard, the mainboard can throttle the CPU to prevent destruction if it detects excessive temperature. In that youtube video, they obviously used a mainboard that reacts fast enough to temperature rise.
Depending on the mainboard construction, CPU overheat protection only works after the BIOS correctly initialized the sensor controller chip - which might be too late when you power on the computer without a heat sink / heat spreader installed.
Reply 14 of 27, by mkarcher
As I understand, the OP is not worried about overheating processors now, but is worried about "untested" processors that might already be destroyed due to use without a heat sink before he or she buys them. The question is just to asses the risk that a Tualatin based processor has been destroyed by careless testing.
Reply 15 of 27, by maxtherabbit
mkarcher wrote on 2021-01-01, 19:00:
I believe you are correct, but it took me reading way too many of his posts to figure it out. It was very unclear
Reply 16 of 27, by debs3759
Ah, OK. I didn't read it that way. I'd say the risk is minimal, most untested CPUs I have tested over the years are just that - untested but OK.
Reply 17 of 27, by The Serpent Rider
Proper motherboard will detect overheat even on startup routine which is indicated on this video featuring Athlon MP: https://www.youtube.com/watch?v=gkrMjX8RwYk
Reply 18 of 27, by Errius
Does any of this apply to Slot 1 CPUs?
Reply 19 of 27, by The Serpent Rider
In general, Slot 1 motherboards had rudimentary overheat protection, which was the point of thermal sensor in Deschutes. But it won't help if you want to insert PIII without cooling.
