First post, by digicube
Looking for SyQuest SQ270/SQ270P and SQ5200C/SQ200 Win95 drivers. I read they were most used on Macs , will they work on Windows 95 too?
Reply 1 of 10, by Horun
SyQuest SQ270 SCSI should work on a Windows 9x machine if you have a proper SCSI adapter. The drivers for Windows will be for the adapter not the drive.
Reply 4 of 10, by digicube
Yes they do. Model is SyQuest SQ270P. I'm guessing the internal drive is IDE or it might be a parallel PCB.
    104.3 KiB
Reply 5 of 10, by Predator99
I have kept that driver from Win95 times, dont know what Hardware is supported, at least my 40 MB SCSI drive was.
    w95s349.rar
    1.07 MiB
    69 downloads
Reply 6 of 10, by lolo799
digicube wrote on 2021-01-04, 21:57:
My mistake, i thought the first Syquest drive with a parallel port model was the ez135.
Found this link:
https://web.archive.org/web/20030218161807/ht … st/syquest.html
From this page:
https://web.archive.org/web/20030206085934/ht … om/drivers.html
Reply 7 of 10, by Horun
lolo799 wrote on 2021-01-05, 00:05:
My mistake, i thought the first Syquest drive with a parallel port model was the ez135. […]
Found this link:
From this page:
Good find Digicube ! I have a bunch of older Syquest drivers and manuals in my archives but they are older than that.
One thing about the older Internal or external SCSI ones is that they mated to a 25pin EXT port on a SCSI card or Mac (like an old SCSI scanner).
The internal drives were standard 50pin so would work with any internal scsi adapter of the time with proper scsi drivers.
The old drivers only support certain scsi adapters BUT the utilities will work with nearly any good scsi adapter if you have the adapters drivers.
Will save your linked drivers as they are newer than the 3.50 I have.
Reply 9 of 10, by digicube
Looking for Shuttle Technology EPIA parallel port IDE adapter Windows 95 driver. The drivers on Syquest website are not for the SQ series drives, they are for EZFlyer and SyJet drives.
Edit: Found it.
https://www.driverguide.com/driver/detail.php … driverid=119051
https://www.helpjet.net/Fs-70945198-41778946- … 67-extract.html
Reply 10 of 10, by digicube
EPIA is DOS driver, it forces Win95 to run in DOS compatibility mode. This disables my IDE and SCSI controller, so my DVDROM is not working. Windows locks up during writing, have to wait until completion before it's free to use again. Bummer.
I might as well remove the IDE drive from the external enclosure and connect via IDE.
Edit: I delete the EPIAHD drivers from loading in Config.sys. Now IDE, SCS ports and DVD drive working. Win95 is now only locking for a few seconds during writing instead of until completion. Much improved.
