First post, by auron
testing a gf4 ti4200 agp8x on a 440bx setup under 98se, i selected 56.64 as driver because it has some features i consider useful over the commonly mentioned 45.23, such as doublescan toggle and refresh rate forcing, but the latter one turned out to be completely broken; every time toggle it on and try to select a refresh rate for a given resolution, it just says 0 hz and upon switching to another tab, it's turned off again. also to make matters worse none of the settings such as vsync, AA etc affect direct3d at all, only opengl.
i should mention that i applied the coolbits tweak, specifically the "CoolBits"=dword:00000003 one, and extra options like overclocking and d3d prerendered frames do appear, so i assume that's the correct one for this driver. am i missing something or were they barely testing this stuff under 98 by that point?
