First post, by RetroLiz
Hi everyone! I recently purchased an IBM Aptiva Series E Model 2158. I'm no stranger to PC parts but I didn't realize how complicated the sound card situation can be. I intend to play Windows 98 and DOS games.
I've heard that an ISA card is better than a PCI card, but I have no idea what the difference is and whether this computer even has an ISA slot.
I don't necessarily care about the "best" sound, but I'm looking for something decent that's available and won't break the bank. It would be nice to get it for approximately $20-$30.
Does anyone have a recommendation?
Thank you!!!
Battlestation: IBM Aptiva Series E 500 (Model 2158)
Sony Trinitron Multiscan 100ES 15" CRT
AMD K-6/2 400mhz
SoundBlaster Live! CT4780
IBM 120GB HDD
256MB RAM
Windows 98 SE
Reply 1 of 13, by Joseph_Joestar
Considering your budget, I would suggest a Sound Blaster Live. It will work great for Win9x gaming while also providing SB16 emulation and General MIDI music for DOS games. However, in older titles that only support FM synth music, the SBLive emulation won't sound so good.
Ideally, you want to pair it with a cheap ISA card such as a Yamaha YMF719-S for genuine OPL3 and better DOS compatibility.
Reply 2 of 13, by RetroLiz
Joseph_Joestar wrote on 2021-01-04, 17:55:
Thanks, Joe. I think that, given the circumstances, I'll get a Soundblaster Live for now and then maybe upgrade in the future if necessary. Tbh, your sound clips in the first link don't sound that bad to my ear. Then again, even back "in the day" (when I was a kid and presumably my hearing was better than it is now) I had a hard time distinguishing the best quality sound cards from the average ones.
AMD K-6/2 400mhz
IBM 120GB HDD
256MB RAM
Windows 98 SE
Reply 3 of 13, by Marmes
If PCI I would also suggest Yamaha YMF7x4 XG . For ISA, what Joseph said. YMF719-F , you can still find them at nice prices. You can try PCI CMI8738 , it has SBpro SB16 and FM.
Reply 4 of 13, by Srandista
If ISA is available, I would also recommend ESS Audiodrive cards (like ES1868 or ES1869). They don't have genuine OPL3, but their ESFM implementation of OPL3 is arguably best in the business (I would say miles better then CQM or Live! emulation), they also have bug free wavetable available and can be bought for next to nothing.
Reply 5 of 13, by Boohyaka
I second the ESS 1868 as a good choice for ISA. They're easy to find, cheap, and I was pleasantly surprised with their quality.
Reply 6 of 13, by Joseph_Joestar
Just a quick note here. While ISA sound cards are excellent for DOS gaming, many of them exhibit crackling and popping when used to play Win9x games. This can be somewhat remedied by disabling sound hardware acceleration, but that usually slows the system down to a crawl.
For best results, use a PCI sound card for Windows gaming and an ISA sound card for playing DOS games.
Reply 7 of 13, by chinny22
Joseph_Joestar wrote on 2021-01-05, 04:20:
Agree with this
OP doesn't mention dos gaming which is the only reason you would want an ISA card
Pure Win9x PC's on a budget I don't see any reason you wouldn't go with a SBLive! in this day and age unless for some very specific reason like compatibility, availability, etc
Reply 8 of 13, by Boohyaka
OP said:
RetroLiz wrote on 2021-01-04, 17:35:
Yet it's true my reply was probably incomplete as I was just seconding ES1868 recommendation from the previous poster for an ISA sound card for DOS.
I would definitely recommend pairing it with a SB Live! for Win9x. That's what I run in my Celeron build.
Reply 9 of 13, by chinny22
So they did, my mistake I'm the one who can't read it seems
Reply 10 of 13, by appiah4
Get an ES1868 sound card if you want a good mix of price/compatibility/sound quality.
Reply 11 of 13, by Caluser2000
I forth the ESS cards fore Dos.
Reply 12 of 13, by Kamerat
When I read the specs of the IBM Aptiva Series E Model 2158 it seems like it contains an ESS Solo-1 PCI sound chip integrated on the motherboard already. This might be very suitable for both DOS and Windows gaming.
YouTube channel
Reply 13 of 13, by dionb
Kamerat wrote on 2021-01-05, 18:19:
Second that. In Windows it doesn't do anything special, but solidly outputs sound at WSS spec 48kHz, in DOS it's one of the best-behaved PCI chipsets.
